Question about ASUS P5S800-VM Motherboard
Boot failure how to fix system boot failure?
    Sergeant:
  • 287 Answers
Try booting from a dos boot disk or windows startup disk, this will prove that HW is OK
then if it boots OK you may have a HDD problem.
Post back results
Posted on Jul 12, 2008
How to fix boot failure on a toshiba satellite l55t-B5334
I would check the boot order is correct and the hdd is not damaged. If all looks OK and still won't boot, insert your system disc in the DVD drive and boot from there selecting repair system as the option.
Oct 10, 2015 | Toshiba Computers & Internet
Tip
How to isolate issues between hardware and software
<p>It has been one of the dilemma of computer users is to identify what is really causing the failure in their computer. Often they think that they bought a defective product since they are getting these kind of errors in the computer. Having an error on your machine does not mean that the machine is defective or needs parts replacement. for all we know it might just need some simple troubleshooting steps to fix the issue. Here is a tip where you would be able to know if you need to bring your computer to a service shop for parts replacement or you can try to fix it at home by doing some troubleshooting steps that would help fix software failure in the computer system.<br /> <br /> On a Windows based operating system, you should always know when the issue happens. It will help much to observe your computer on how it boots up and what it does before you get to the desktop screen. Take a note on where and when exactly the error occurs.<br /> <br /><b> Power Failure:</b><br /> <br /> This is an issue where there are no lights on the power button of your computer, whether it is a portable system or a desktop computer. Obviously this is a hardware failure. surprisingly, discharging the flea power of your computer sometimes resolves these kinds of issues. Otherwise, you will definitely need to have a local technician look at your system for parts replacement.<br /> <br /><b> Note:</b> flea power is the charged power of our computer system. A computer system is made up of electronic components such as capacitors which hold electronic charges. To be able to discharge it, you should disconnect all power source from your computer and hold the power button for at least 5 seconds.<br /> <br /> <br /><b> POST Failure:</b><br /> <br /> POST is an abbreviation for Power On Self Test. as the name implies, it is the test that a system goes through to test the basic hardware components needed for a computer to boot. The components that it tests are as follows: Processor, BIOS (Motherboard), Memory, keyboard and video card. If there is a POST failure, the system would give you a black screen with lights on the front panel. Sometimes it will give you beeping sounds which would normally mean that you have a memory failure on your system. If you encounter such issue, you will need hardware technical support to guide you isolate further on what could be causing the failure.<br /> <br /><b> Boot Failure:</b><br /> <br /> Boot failure is when the computer is able to complete post. You will be able to know this if you hear a single beep on your computer. Isolating a boot failure from a post failure simply requires you to boot to the System Setup/configuration Screen (BIOS). If you are able to get to the BIOS, that means all the POST hardware component are good to go. However, booting to the BIOS differs per system. You just need to do trial and error on the following keys to tap as you turn your computer on.<br /> <br /> Del<br /> F1<br /> F2<br /> F10<br /> F9<br /> ESC<br /> <br /> To isolate an issue whether it is a software or a hardware issue, you just need to boot from the BIOS. If you are able to boot from the BIOS, chances are it is not a hardware failure and needs servicing.<br /> <br /> <p><img src="vincent_von_0.jpg" /><br /> <p><br /> If booting to the BIOS works, to further isolate the issue whether it is the advanced software, you need to boot to Safe mode. Safe mode is a troubleshooting state where only the basic applications and drivers are active. If you are having errors or boot failure, try to boot to Safe Mode. If you do not encounter the failure in Safe Mode, that means that there are advanced software being loaded in your operating system that fails. It is just a matter of knowing what that software is.<br /> <br /><b> Booting to Safe Mode:</b><br /> <br /> 1. turn computer on and tap on F8 before Windows starts.<br /> 2. You will be getting the Advanced Boot options. Use the arrow keys to get to the option for Safe Mode.<br /> <br /> <p><img src="vincent_von_0.png" /><br /> <p><br /> <p><br /><b> Safe Mode Definitions:</b><br /> <br /> Safe Mode: Just basic software are being loaded. Network drivers are not included which means no internet connection<br /> <br /> Safe Mode with Networking: Basic software and Network drivers are being loaded.<br /> <br /> note: for Vista or Windows 7, it includes wireless network drivers. This means that you can still connect to the internet with a wireless connection. In Windows XP, the wireless driver is not included even if you boot to Safe Mode with Networking<br /> <br /> Safe Mode with Command prompt: this is a troubleshooting state where you will be able to utilize DOS based commands.
on Jul 15, 2011 | Computers & Internet
Disk boot failure
Yes, this is have drive issue. May not be fixable with the restore disk. Test your hard drive to see if it's still in working order.
May 21, 2010 | Microsoft Windows XP Media Center Edition...
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
PXE-E61
"PXE-E61 Media Test Failure, System won't boot"
  1. Go to Bios Settings
  2. Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
  3. Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Computers & Internet
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
Boot failure
Here is the fix: Boot Failure
Sometimes just downloading and following the procedure in Boot Failure does not work, because the system files cannot be overwritten, in this case follow the additional instructions here to delete manually the system files.
Oct 14, 2008 | iRiver PMP-140 Digital Media Player
Iriver pmp-140 digi.media player prob help plz
Oct 04, 2007 | iRiver PMP-140 Digital Media Player
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
System file has an error.
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
ASUS P5S800-VM Motherboard Logo
255 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
