Question about Pioneer PDP-507XD 50 in. Plasma Television
Problem with pioneer plasma pdp-507xd
If i on the t.v. set it get on for the second and goes in stand by mode and poweer indicator red light blinks twice,i open the set and red led on poweer board and red led of video board is on after a second,
is it a short circuit or excess current drain problem?
is anyone have circuit diagram?
pioneer people dosen't have interest to guide,
his interest is only to get good money from coustomer under the name of authorise service,
  • islandmantf Sep 14, 2008
    I've just come back from a 3 week holiday, prior to going away tv was turned off into standby via remote then turned off fully via button on tv. The tv was still plugged in though via a ups. I turned tv on via button & standby light came on, I pressed standby button on remote, the on button (blue)came on & then turned red (stanby) & now blinks every 2 or 3 seconds. I turned tv off, unplugged power supply (leaving it for 5 minutes) several times & tried again, but still have same problem. My 507xd is 18 months old. I contacted Pioneer 3 times but it's now been a week & I'm still waiting for them to come back to me.
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
  • 225 Answers
SOURCE: Can't turn on from Stanby mode
I would assume the power board has a problem. A tech could possibly repair it without replacing the whole board.
Posted on Nov 14, 2008
  • 6784 Answers
SOURCE: where can I sell a pioneer pdp 5070pu plasma tv for parts?
HI, the best way to do this is to disassemble the set and post all the individual internal parts like the power board and main PCB logic and v boards, on line on a e-bay type of sale forum. this way, you can make more money. if you post the entire plasma screen with the crack as is, you will not get many hits. is will be assumed that it is damage goods.
Breaking this set down and, posting the internal circuitry piece by piece will make you more money in this case. The power supply board will sale for at least 289.00. and the main logic(PCB) will sale for 300 to 350. i would go this route to maximizes your gain.
Posted on May 20, 2009
  • 4 Answers
SOURCE: Will the Pioneer PDP-R03E Plasma TV Media box work
Yes it will
Posted on Jan 14, 2010
SOURCE: The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Posted on Jul 19, 2010
Pioneer PDP-R04U receiver blinking Help!?!
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link Pull up older posts.
Nov 28, 2013 | Pioneer PDP-4350HD 43 in. Plasma...
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
Pioneer PDP-436PU TV blinks red 10 times
Most likely a bad power supply board= you are going to have to find a Pioneer dealer to get it fixed or even get the part--many shops including the one I work for will not touch this brand of set.
Apr 25, 2012 | Pioneer PureVision PDP-4340HD 43 in....
We have had problems switching on our Pioneer PDP-507XD plasma tv. The standby light just flashes. We were advised to change the power supply unit. We hav4e done this and it has not solved the problem ...
I've been running across a lot of plasma tvs where the power supplies are not bad, but the X & Y-sustain boards are faulty. My advice is to change those boards out as they are responcible for lighting the plasma gasses in the tv. You can attempt to replace one at a time (cost reasons), but it is recommended to changed both at once.
Hope this helps, please rate. :)
Apr 11, 2011 | Pioneer PDP-507XD 50 in. Plasma Television
I have a Pioneer PDP-5030HD plasma and the plasma display does not turn on. The standby/on power indicator light on plasma display is blinking red (after turning it on with my remote, it turns green for a...
First check batteries in the remote are charged.Try pushing one of the channel selection numbers on the remote as it may be the off/on on your remote is stuck or has died completely. if this does not fix the problem try unplugging the set from the wall wait 5 mins (approx) and re plug into wall socket and try turning on .
Oct 25, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer PDP-507XD 50 in. Plasma Television Logo
202 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
