SOURCE: dificulty in configuring wrtg4g
There are three major steps to setting up a wireless router.
First
set up WAN side access to the internet. For this you need information
about your internet service provider. Please respond with your internet
service provider's name or better yet a link to their help/support
website.
I assume you already have access to configure the
router at 192.168.1.1 if not please do the following. Open Internet
explorer and enter 192.168.1.1 where you would enter fixya.com and
press enter -- do web pages appear in your screen from the wired
computer. If so we have manual access to configure the router. If not
let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This
process will require interaction and several iterations of instructions
to complete. Please add a comment to this request with the necessary
information if you with to proceed in this fashion.
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
SOURCE: my IMAC ethernet connection to my wrt54G is much slower than wifi
Then you have your settings wrong, as I have the same setup for many years. The setup page of your router should be set basically default, it should be all set to auto ip and other than your dns there should not be anything else to set. I have 3 wireless and two wired devices and all of the computers .And the speed is constant,,something is wrong with your settings, if you can take a screenshot by opening the router homepage and hitting the print screen button on your keyboard, you can then hit paste on here and it will past the entire thing on here to examine
SOURCE: configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
try another port..try use static on ps3 settings manually ip address subnet mask etc
Can you state what the ip address is for the router ? and what is the ip address for the Computers and the ps3. Does the router have a dhcp server and if yes have you set up the default gateway to the router's ip address in the dhcp server leases and the computers and ps3 are set to get ip automatically or are they static .
What subney mask is the router using ? 255.255.255.0 ? and what subnet mask as the computers and ps3 ?
