Question about Pioneer Car Audio & Video
My Pioneer cd radio player in a mazda mx eunos ejects cd's as soon as they are inserted.
  • stevebenaven Jul 13, 2008
    I have used a cd lense cleaner, it did not solve the problem.
    Brigadier General:
  • 6,966 Answers
This could be indicative of a dirty lens or at worst defective. Have you tried using a CD cleaner similar to those used in computer CD ROMs?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 13, 2008
  • Louie  Role
    Louie Role Jul 13, 2008
    If the unit is fairly new perhaps your best bet would be to seek warranty repair services. Should you be considering a DIY (do-it-yourself) the bulk of the repair job would be removing it from its location. Thereafter, it would be a matter of removing the panel covering and checking the inside. Sometimes the unit would only require manual cleaning, a spray of compressed air, a spray of electronic contact cleaner specially on the mechanical portion and re-application of appropriate lubricant. As stated earlier should these be not corrective, then perhaps it is time for a replacement unit considering the cost of repair and the downtime.
  • Louie  Role
    Would you know the exact model number of the Pioneer unit? Would it be a DEH-P3000, 4000 or another pls?
Cd Player Automatically Ejects Disc
Hi there:
This normally happens when the laser gets dirty and can't read a cd. more common in a smokers car or if living in a dusty area. You can get a cd lens cleaning kit. just a black cd with alike a fake eyelash attached to the bottom it spins it bushes dust off the optical eye of the laser...this is what actually reads the disc.
Other choice, the mechanical system of the player is stuck thats why it cant read the disc anymore, you should put some oil on the mechanical part to lossen some stuck up parts.
Als HERE other Mazda opinnions.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | 1997 Mazda MX-5 Miata
Firing order Mazda eunos 30x
Australian version, also called Mazda MX-3 Precidia, Eunos 30X, Eunos Presso, Autozam AZ-3, Mazda AZ-3.
On 1.8L (K8) and 2.5L Engines Firing order: 1-2-3-4-5-6 Distributor rotation: Counterclockwise
Hope this helps.
Jun 05, 2012 | Mazda Eunos Cars & Trucks
A cd is stuck in my Pioneer AVIC Z1 nav system. I
This is a tricky one you could try tyaking the top of the radio off and see if you can help slide it out. Another trick is to get a thin stiff piece of cardboard like the back of a writing tablet cut a strip apx. 2" wide and 6" long. Take a piece of ducktape and with the sticky side up insert under the disc hit eject and see if that will coax it out.
Jul 29, 2010 | Pioneer AVIC-Z1 Car DVD Player
1991 mazda 1600 eunos mx5.Does it have chain or bet cam drive?Ple
It has a cam belt that needs to be renewed every 60000 mls
Mar 07, 2010 | 1991 Mazda MX-5
When replacing the fuse in my 1993 mazda miata. the fuse instantly is blown as soon as i turn the key. has and pioneer aftermarket radio head unit.
Sounds like too much draw on system. To test turn off radio. I would route separate heavy wires to power radio. Use a 12 volt relay to control (e.g. 30 amp auto relay). Connect normal radio power to power relay (so that key controls radio)
Jul 10, 2009 | 1993 Mazda MX-5
Pioneer radio/cd player
The problem has not been solved. I tried a cd cleaner, but that was also ejected immediatly. The cd player was working perfectly but gradually it began to eject certain cd's and then any cd that was inserted.
Jul 13, 2008 | Car Audio & Video
Pioneer DEH-1900MP error AO
I have the same problem CD will not eject and getting error :S
Oct 19, 2007 | Pioneer DEH-1900MP CD Player
Cd won't play
Easy fix, look at the front of your CD player, you should see a little pin hole, insert a paper clip into it and the pop the CD tray open.
Jul 23, 2006 | Panasonic CX-DP801 8-Disc CD Changer
Car Audio & Video Logo
56 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
