Try a hard reset, which simply means unplugging the power cord, and replugging it after 4 hours have passed. (Turning the switch on and off does not work). This technique reprograms the electronics, to a certain extent. If the picture does not return, then you need the expertise of a TV repairman.
Hope these suggestions help you out. Please take a moment to rate the info that I have provided, by using the rating system below. Thanks.
my akai pt5250a was working fine and then cutoff and now a red light is blinking but it wont come...
(More)
my akai pt5250a was working fine and then cutoff and now a red light is blinking but it wont come back on.
We have a Sony Videoscope XBR TV model kp53xbr45 we need to move. We do not have a manual. It is so...
(More)
We have a Sony Videoscope XBR TV model kp53xbr45 we need to move. We do not have a manual. It is so heavy, can it be separated into two pieces?
We just got a used fwd-42pv1 flat panel TV as a gift and we can't seem to make it work. We got it...
(More)
We just got a used fwd-42pv1 flat panel TV as a gift and we can't seem to make it work. We got it without cables or manuals. We tried to plug in the comcast cable and we got nothing. We turn it on and use the remote but we only get "input1" on the upper left corner. The menu shows also, but that's it. We don't get a signal. Is there something we should do first? Do we need a specific cable to get the signal? We'd appreciate your help.
