Question about Panasonic Televison & Video
My TX-47P600H REAR PROJECTION TV on startup i get a few seconds of sound no picture then a red light just under the screen flashes intermittently (3 flashes pause etc...) Is it the globe? or some other issue please advise
  • 4 more comments
  • carole heaven Jul 12, 2008
    I have conflicting advice one solution suggests power supply fault and the other suggests faulty convergence IC's neither provided how to fix the fault
    I already have a manual which does not contain the information I require to fix this problem. Can anyone actually provide a diagnosis and step by step solution to fix this fault
    my TX-47P600H REAR PROJECTION TV on startup i get a few seconds of sound no picture then a red light just under the screen flashes intermittently (3 flashes pause etc...) Is it the globe? or some other issue
  • carole heaven Jul 13, 2008
  • 1,512 Answers
Hi
As you have seen there are many varying opinions on what is causing the problem for your television. Needless to say, the set has an electronic FAILURE, and will require repair work in an area indicated by the three flashes. As Ginko has suggested, it is probably in the convergence stages. If have good experience at soldering and fault-finding a complex device such as a TV, then you should be able to just leap in, locate and replace the offending convergence IC, dry or failed electrolytic capacitors, pico circuit protector fuses, and fusible resistors. . If this is all mumbo jumbo to you, then attempting to fix the set yourself may be the wrong approach. Dont forget the residue voltage and high voltage present in the set THAT STOP YOUR HEART AND CAN KILL OR INJURE YOU!! Please take this advice. Get a repair a qualified repair tech to have a look at it for you. You have a good idea of what the problem actually is, so ring a tech or 2 and ask them what the 3 flashes mean. If they know Toshiba TV,they will then tll you exactly what I have have just said to you. Well it is what I would say to you at least....
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jul 13, 2008
  • Graeme Ross
    Graeme Ross Jul 13, 2008
    I should say Panasonic NOT Toshiba.... need that early morning coffee :)
  • Graeme Ross
    Graeme Ross Aug 07, 2008
    Gidday mate... how did you go with getting the set sorted out. Any luck? Love to hear from you
    robotek
  • 2,071 Answers
PDF] click for ypour manual Operating Instructions TX-47P600H
Posted on Jul 12, 2008
  • 2,427 Answers
Http://hardware.mcse.ms/archive144-2005-8-p2.html Yes it may be the convergence The link contains a step by step procedure in troule shooting and repairs of the Give Unit
click here
http://hardware.mcse.ms/archive144-2005-8-p2.html
  • Rishi Roshan Ali Jul 13, 2008
    Well with 3 seconds of sound and no picture I'd Say the Back light is shot, and when the tv detects this it trips the fail safe and displays the error code in the blink,,
    Check your back light
  • Panasonic Master
  • 19,396 Answers
Here are Panasonic flash codes:
Flashes : Fault:
1 ----------------- +140 v.
2 ----------------- Low DC
3 ----------------- Convergence
4 ----------------- HHS
5 ----------------- IC 4011
6 ----------------- IC 4018
Three falshes codes means that one of the two convergence ICs had blown, the pico fuse at the base of IC must be tested and faulty IC replaced.
  • 105 Answers
THIS IS A COMMON PROBLEM WHICH I HAVE ALSO EXPERIENCED DURING THE WINTER TIME.SOME TIMES IT MAY BE ALSO DUE TO THE CIRCUIT DAMAGE .SO TRY TO CHECK THE CIRCUIT BUT TAKE CARE SINCE THERE IS A HIGH VOLTAGE AT THE BACK OF IT.TRY TO CHECK THE CIRCUIT YOURSELF OR TRY TO SEEK THE ADVICE OF A SERVICEMEN OR TRY TO SEARCH ON THE PANASONIC WEBSITE
  • 67 Answers
Support.panasonic.co.nz/docstore/TX47P600HZ%20book.pdf
  • 813 Answers
    Genius:
  • 1,665 Answers
It must be power supply fault.
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
HOW TO FIX CONVERGENCE IC FAULT & HOW MUCH COST APPROX
Panasonic Flashing codes:
1: ----------------- +140 v.
2: ----------------- Low DC
3: ----------------- Convergence
4: ----------------- HHS
5: ----------------- IC 4011
6: ----------------- IC 4018
3 is convergence, either one of the two convergence ICs faulty, or something else (capacitor etc.) has blown on convergence board.
Jul 13, 2008 | Televison & Video
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
