Question about Brother CS-100-T Computerized Sewing Machine
I get the e1 message
Machine always display e1. presser foot down as well
  • 3 Answers
I have a different model but I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Posted on Aug 04, 2008
E1 error brother ce 4000
Hi.
You can get the E1 error if the presser foot is not down. If you use the walking foot attachment it can keep the foot from coming all the way down.
Apr 08, 2017 | Brother CE4000 Computerized Sewing Machine
Brother ce5000prw e1 code
Presser foot sensor/switch is either stuck or broken.
Jul 19, 2014 | Brother Sewing Machines
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
What should I do when error message E1 hapend
An "E1" message appears on the panel. Description: The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
Mar 02, 2010 | Brother CS-6000
When I push the pressor foot down my machine flashes E1
Is the presser foot lever up or down? It should be down before you step on the foot controller or use the start/stop button.
For additional information, try this URL: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_cs6000btieus.html?reg=us&c=us&lang=en&prod=hf_cs6000btieus
Aug 24, 2009 | Brother CS6000i Computerized Sewing...
Persistent E1 message
some machines have a presser foot sensor or switch which prevents the machine sewing if the foot is not down.
if your presser foot is down and you still cannot sew the switch or switch actuator is most likely damaged. you will require a tech to repair this.
scott
Jul 26, 2009 | Brother CS6000i Computerized Sewing...
Presser foot down, but still get error "E1"
I have a different model with the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Mar 26, 2008 | Brother CS-100-T Computerized Sewing...
Jan 01, 2007 | Brother CS-100-T Computerized Sewing...
Brother CS-100-T Computerized Sewing Machine Logo
156 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
