Question about LG Refrigerators
Just bought new side by side lg fridge and want to know correct temperature settings for fridge and freezer when i make the adjustment in 2 days time presently it is showing -23 degrees for freezer and 2 degrees for fridge and the manual says to run for at least 2 hours before putting food in and then adjust those settings in 2-3 days time
    President:
  • 1,462 Answers
Freezer temp should be set to approx -18 to -22 degC
fridge should be set to +4 to +6 degC
Posted on Jul 12, 2008
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Frost in Freezer of BRAND NEW LG FRench Door Fridge!
After converting C to F, I reckon your freezer should be set a bit lower than -2 degrees for five star food storage. I think -15 F should equate to the ideal temperature of about -25 C for five star food storage.
Whatever moisture enters the freezer will become frost. I have not yet seen a freezer that is entirely frost-free and I have no way of knowing whether the amount of frost in your freezer is excessive.
Every time the door is opened, every time somebody exhales while the door is opened and every time unfrozen or barely-frozen food is added there will be moisture and therefore frost...
It is a good idea to use a separate thermometer to check/verify the internal temperatures.
A new fridge or freezer can take a few days to settle and no decisions should be taken before it has been given a fair trial. One point to be aware of is a fridge or freezer that is properly stored and then transported vertically can be switched on as soon as it is delivered but if it has been laid down or severely tilted it should be stood for several hours before switching on. Ignoring this could be detrimental to the performance and/or the life span.
Another important point is the appliance should be adjusted so it is as close to plumb or spirit-level vertical as possible to ensure long life and reliable operation.
Mar 01, 2017 | LG Refrigerators
I bought a whirlpool fridge freezer last two weeks it was working fine but i noticed that the freezer is making too much ice when i set it at temperature 7 which is melting and i keep seeing water under...
Water under it is fine as long as it is not on the floor. It should be in a pan that came with the unit. You should have 2 temp setting for the unit..1 for the freezer and one for the frid. set the freezer for 5 to start. and then set the frig at 5. and adjust only the fridg side after a few hours. If this does not wrok call the place you bought it from as it may have a bad swthch on the indoor fan or a bad flapper door that allows cold air from the freezer to cool the fridg. But you have to start at mid range and adjust only the fridge side moving it up or down buy 1 number at a tiem.. Let me know know. I hope this helps Jon
Aug 13, 2011 | Whirlpool Heating & Cooling
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
LG LDC22720SW ECU reads 5-6-7 on freezer side
I have a similiar problem with my LG refrigerator. The freezer settings get stuck on 6 and 7, while the refrigerator side is showing nothing. Pushing the buttons to adjust the temperature does nothing. The whole time, my food is getting spoiled.
Jun 28, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
LG French door fridge freezer not freezing
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
Jun 26, 2009 | LG LFC20740ST Stainless Steel
I have a Whirlpool side by side fridge freezer (brand new only 2 days old) the alarm is going off and the two lines side by side on the freezer side are flashing?
The alarm is set off when the freezer is out of the differential range of the setpoint. In other words, the freezer is still too warm. If you press the alarm button, the sound will stop but the light will stay on. If the unit is working correctly and cooling properly, this light should go out once the cabinet temperature gets close to the setpoint temperature. Hope this helps you.
Mar 04, 2009 | Freezers
Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Sep 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Ie tube freeze
You may need to balance the distribution of cold air between the freezer and refrigerator section.
The temperature setting influences both and there is normally a control that lets you divide the cooling between the two compartments.
If you don't have one, get an inexpensive (<$5 US) refrigerator thermometer, normally a simple dial-type, and monitor your refrigerator temperature (maybe somewhere in the middle) overnight when not often opened, set the main control to get the temperature between 40-45 degrees F.
Then check the freezer temp.; it should be <10 degrees F (0 is better), then swap back to the fridge to correct the main setting.
Go back and forth until you have both compartments close to the mentioned ranges.
Jun 24, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerators Logo
204 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
