When I download and install adobe, I get adobe reader icons on all my desktop programs, and nothing will open. ALso I can't open PDF files.
Had a problem with Adobe. Not sure what I did, but most of the icons on my desktop looked like an adobe icon. If I clicked on any of the icons like this, including a pdf file, it wouldn't open the file or program. Instead I'd get a warning box that said something like there is no file to support my request. So I removed adobe from my computer using the control panel, and everything worked ok except that I couldn't open a PDF file. I reloaded Adobe reader 9.0, and had the same problem again, so I again removed Adobe from my computer, and did a restore and now everything seems to work fine. Oh, by the way, I have Vista Home Basic as my operating system.
Posted on Jul 12, 2008
How do you open and edit pdf documents on a hp omni 100 pc
You need to download and install adobe reader or PDF installer. In order you to edit, open and modify files in pdf.
Oct 09, 2011 | HP Omni 100 PC
I cant open my file in pdf version. what should i do?
You need Adobe acrobat Reader to open the PDF File
Download it from here: http://get.adobe.com/reader
May 24, 2011 | Computers & Internet
Cannot open Reader on Desktop - click the icon and nothing happens
If you mean Adobe Reader, then either the shortcut has lost the information on what file it is associated with or Adobe Reader is no longer on the computer. If you recently transferred to a new computer using the Windows Transfer Wizard, the shortcut may be pointing to a different version folder or to a not yet installed program. Remember the Transfer Wizard does not install the programs and doesn't transfer the registry information about installed software from the old computer.
For Windows:
First, right click on the icon and then click on Properties. That will give you the location and name of the program it is associated with (as it was created). For example: on my Win7 32-bit machine this reads "C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe". Next open the Control Panel Programs list, see if Adobe Reader is listed. (For Win7, this is Start > Control Panel > Programs. WinXP, look for the Add and remove programs section.) Open Computer (My computer) and navigate to C:\Program Files. See if you have an Adobe Folder and then the reader folder location. (If the folder exists, check for the exe file and if that full folder name matches the one for the shortcut.)
If Adobe Reader isn't installed, go to http://www.adobe.com and follow the link on the right hand side to download and install Adobe Reader. Then remove the bad shortcut since a new one will be added to the desktop.
If you have Adobe Reader installed but the shortcut isn't pointing to the correct location, you can create a new shortcut by right clicking on the exe and choosing create a shortcut. Before you do this, double click on the reader.exe and check that it does launch. Otherwise, uninstall and reinstall the program.
I hope this helps.
Jan 12, 2011 | Computers & Internet
I received a PDF attachment but can't open it because this is what comes up : This file does not have a program associated with it for performing this action. Create an association in the Set Association...
It simply means there's no PDF reader installed on your computer. Or if it's already installed, then there must be some default pdf reader recently set incorrectly to another application/program. If you are sure that there's a pdf reader, like adobe reader, foxit reader, etc..etc.. installed on your computer, follow the steps below:
Right click the pdf file (i guess you've downloaded the pdf file), click "properties", there you'll see a "change" or "Browse" button on the general tab, click change or browse and locate the program to open the pdf file, select it and click "Ok" then "Apply", close the dialog box and double-click the pdf file, it'll open without any problem. You can also directly open the file on your internet browser like Internet Explorer, Google chrome or Firefox etc..etc.. Simply right-click the pdf file and select "Open with" and browse the internet browser and click it.
If in case you need a pdf reader to open the file, click here to download adobe reader. Open the link, click "Download" proceed with the onscreen instructions and install the program, if you are asked to confirm whether this problem to be made the default pdf reader, confirm it and and finish the installation by clicking finish. Now open the pdf file, there'll be no more issues.
If you need further help, let me know, it would be much appreciated if you can let me know how you open the file.
Good luck.
Thanks for using FixYa.
Sep 02, 2010 | Microsoft Windows Vista Home Premium...
Cant open pdf
Make sure only adobe 9 is the only version of adobe reader you have installed on that computer. Then go to where your PDF file is and right click on it with the mouse and go into properties.
In the general tab where it says type of file it will show you what program is opening up the PDF file. Click on the change button and where it says recommended programs see if Adobe reader is there, if its not then down below where it says other programs click on the down arrow and see if adobe reader shows up there. If it shows up in either section then choose it, then click on apply, and then click on okay.
Now if for some reason adobe reader doesn't show up in either section, then you'll need to browse for it. It normally installs itself in the program files folder, then double-click on it and go into the adobe folder, Adobe 9.0 and then the reader folder. The name of the reader program looks something like acrord32 and it will say application to the right of it. At that point choose it and apply the changes so it opens up with Adobe reader.
This should cover everything, if your still having problems, let me know and I'll help you out further.
May 22, 2010 | Dell Dimension 4600 PC Desktop
When I open an attachment-pdf for instance. or any attachment for that matter. The windows media player opens, with an error message saying it cannot open this type file. is this an adobe reader problem
Sounds like your files are not assigned to the correct program.
Open Windows Explorer and find a pdf file.
Right click on it and choose Open With...
Select Adobe Reader and check the box at the bottom that says:
Always use the selected program to open this kind of file.
Click OK.
All pdf files should then open in Adobe.
You can do the same with any other type of file by choosing the program you want to open it with.
Thanks for using Fixya.
Mar 31, 2010 | Computers & Internet
I cannot open pdf files and would like a free download program for it if I need it.
You'll require Adobe PDF Reader installed on your computer to open .pdf files. If it is not already installed on your computer, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Mar 11, 2010 | Computers & Internet
When I try to open a pdf file, the icon is different and does not open in Adobe, but in MS Word 2007, which of course is does not open properly. This computer (Gateway M6752 laptop)has Vista Home Premium,...
Hey mrbickham,
In some instances, updating existing software or installing new programs onto your computer can cause issues such as what you have encountered. Fortunately, re-associating .PDF files with Adobe Acrobat Reader instead of MS Word 2007 may be all that you need to do. Most versions of Windows allow users to select the program they want to use to open any given file type, and can usually be done by following the steps I’ve provided below.
1) Right-click on the .PDF file icon.
2) Choose "Open With" from the menu that appears.
3) When you highlight the “Open With” option a submenu should appear. Click on the link in this menu that says “Choose Program.”
4) Another window should then open, providing a list of the available programs on your computer. Choose Adobe Acrobat Reader from the menu and check the box next to it.
5) At the bottom of the page there should also be an option that says something similar to "Always use this program to open this file type." Make sure that this option is enabled.
6) Click "OK."
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 23, 2008 | Computers & Internet
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
