Question about Husqvarna Designer I
Breaking thread Hello. Found this site looking for a solution. My thread keeps breaking on my Designer I. Anyone know if I can tweak something? Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
Try adjusting the tension in the "Set" menu. "Tweaking" anything else may end up costing money.
First, make sure the hook area under the bobbin case is free of debris. Try a new bobbin and a new spool of thread with a new needle, full inserted. If the needle threader isn't lining up, the needle may not be in right.
Posted on Aug 08, 2008
The upper thread keeps breaking whenever I sew even though it is always properly threaded and the needle is fine
check the age of the cotton
cotton is not a single thread but a series of fine threads bonded with a glue
old cotton glue breaks down and the thread separates easilty
next check that the needle is installed correctly with the grove ( thread groove away from the bobbin hook
check the needle and hook timing because if it is off a fraction , the hook will pierce the the thread causing it to break
next check that the eye is the correct size for the thread in use
a needle eye too small for the thread thickness will jam the thread ans not let slide through the eye properly
Nov 25, 2017 | Sewing Machines
How do I stop the machine breaking the top thread when I'm sewing?
There is either an error in the way it is threaded or the tension is set to high.
Nov 21, 2017 | Sewing Machines
First Thread breaks on nelco 928 why?
Remove all the threads.
Replace the needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify each thread is in the correct thread path.
ALWAYS THREAD each in the order specified or you will continue to have problems--for a lot of machines, the order is Upper Looper, Lower Looper, then needles.
Check the tension on that particular thread--too tight, it will break.
Breaking thread after about an inch usually indicates it is mis-threaded--a guide has been skipped or threaded out of order or the thread may be wrapped around something.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Sew What Up View thread Help Needle thread keeps breaking
Why does my machine break the thread a lot? A juki cp 130
tension too tight or incorrect threading, or bad thread.
Mar 13, 2017 | Juki Sewing Machines
I am having trouble with the free motion on my Viking SE. I can feel the thread sticking up on the back and the top thread keeps breaking. I have tried changing thread (four times) and changing needle...
I presume you have set the machine for free motion quilting in the Menu? There are so many things that could be causing this, and so many variables for tweaking it to optimum performance. What foot are you using? What thread? What needle? What menu setting? Have you tried loosening the top thread tension? Bobbin tension? I will keep a lookout for further posts from you with a bit more info that we can start working on. I have a Designer1, not the SE, but have used an Se so will try my best to help.
Dec 15, 2010 | Husqvarna Designer I
When I am trying to do an embroidery design, the top thread keeps breaking. What could be the cause of this?
check your thread tension
check needle could be bent-blunt or damaged
thread could be caught on something
on some sewing machines the thread comes off the thread take up lever
Sep 23, 2010 | Husqvarna Designer I
Husqvarna Viking Designer I breaking needles
Make sure that the metal plate is locked into position- Hope that helps!
Jan 20, 2010 | Husqvarna Designer I
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
Husqvarna Viking Designer 1 Beeper
You can't. Believe it or not, it is supposed to be helpful! I know it is annoying though. I have owned my Husky for 10 years and it isn't something you can get rid of.
Nov 17, 2007 | Husqvarna Designer I
Sewing Machines Logo
169 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
