Question about SanDisk Sansa e270 MP3 Player
Sansa e270 freezes when USB cable disconnected
Iam having sansa e270 6GB when i remove usb cable after charging the unit or loading songs etc. the connected screen remains there. It does not switches off. It was having firmware 01.02.18A . Degraded it with 01.00.12A but problem remained the same. Then upgraded it to 01.02.24A still the same problem. Now every time i recharge the unit i have to hold menu/power button for 10 seconds to switch off the unit.
Please help me out of this problem
Avinender
  • avi12singh Jul 17, 2008
    What is this rockbox thing . Can u please explain in detail?
Reformat the whole thing with Rockbox. That's the whole point with buying the Sansa, as far as I understand.
Posted on Jul 16, 2008
E270 (6GB) not working
Sounds like the problem I had. I followed the instructions for "Load image failed" appears after updating e200 firmware". It's item #3 in the list.
http://www.sansa.com/support/sansa_e200/faqs
I found the necessary files in the forum (my Sansa is the e270 v1). The files can be found here:
http://mp3support.sandisk.com/firmware/e200/e200v101.02.24a.zip
I hope this helps.
Aug 10, 2009 | SanDisk Sansa e270 MP3 Player
Song's will not appear on Sandisk Sansa e270 (6GB)
Go to http://www.sandisk.com/ and search for your mp3's programming and download it, no promises, but it worked for my sansa fuze
May 13, 2009 | SanDisk Sansa e270 MP3 Player
My Sansa e270 Will Turn On Then When It Starts Loading It Will Get 3/4 Of The Way Then It Goes To A Black Screen.What Do I Do?
try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 01, 2009 | SanDisk Sansa e270 MP3 Player
Getting to recovery mode
You have to Download the Sansa Recovery Tool from Sandisk's website first. Then, disconnect the Sansa from the computer, press and hold in the REC button, and then reconnect the Sansa while holding the REC button.
-Tha Mp3 Doctor
Feb 15, 2009 | SanDisk Sansa e270 MP3 Player
Sansa e270 ....computer no longer reads content of sansa
Well, the reason you can't see some of the songs is because they are in a hidden folder. To access the hidden folders, you have to go to computer, then folder options, and check unhide hidden files and folders. If you go back to sansa, you should see a light colored folder that is titled music.
Dec 08, 2008 | SanDisk Sansa e270 MP3 Player
Music not synchronized
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Oct 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e270
The song does not have transfer rights - you must upgrade to Napster To Go.
Jun 21, 2008 | SanDisk Sansa e270 MP3 Player
Help Please
What happens with my Sansa e270 (6 gb) is when i connect it to my PC the connections seems to be patchy and it will not download or delete songs, when i unconnect it, it is as if i have not done anything. I can only download songs at small increments, and many times the connection is not working. The wires seem to be fine, and the USB ports work, and the cable seems ok. This is very annoying.
thanks for helping!
Apr 05, 2008 | SanDisk Sansa e270 MP3 Player
Sansa e270 problem
You cannot - the firm upgrade delted them - you will have to refind them and redownload.
Jan 21, 2008 | SanDisk Sansa e270 MP3 Player
Can't play sansa e270
if i were u id just turn it off,take out the battery and get a fresh 1 and then see what happens.........ive been having problems with my sansa to:)
Dec 06, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e270 MP3 Player Logo
78 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
