Question about LG KU990 Viewty
Pictuers goes bright
I have a problem with the camera, the picture goes bright and spread
when i took them.
I tried to play with the iso manually and it doesn't help .
any idea
Try with the settings in the camera... show me a sample pic, i can tell u which settings to change
Posted on Jul 18, 2008
Hi When I try to take pictures of the moon at night, the all I get is bright light without any detail. The sensor seems overloaded and the image seems smudged. I have tried with the intelligent...
All automatic-exposure cameras try to render the scene as a middle gray. The moon is a small portion of the total image, so the camera concentrates on the sky. In trying to get enough light to make the sky go from black to gray, the moon gets completely overexposed. What you want is the moon properly exposed, even if that means the sky goes completely black.
For a full moon, you want the same exposure you would use at noon on a bright day. If you think about it for a moment, it becomes obvious. The full moon is simply a landscape at high noon. Unfortunately, the camera can't know that.
Set the camera to manual. Start with the "Sunny-16 Rule", which tells you to set the aperture to f/16 and the shutter speed to 1/ISO. So for example, set the ISO to 200, the aperture to f/16, and the shutter speed to 1/200. Look at the result on the screen and adjust the exposure as needed.
That was for a full moon. For other phases you may need to add exposure, but the "Sunny-16 Rule" will still give you a starting point.
Jun 18, 2011 | Panasonic Lumix DMC-LX3 Digital Camera
All of my shots are grainy--really grainy. My old 8 mpx camera took beautiful, tack-sharp photos. This is 14 mpx and it looks terrible. Someone suggested that maybe the contrast needed to be adjusted ...?...
Unfortunately with higher mpxs sometimes you pay for it with higher noise levels. The smaller pixels are more sensitive and can cause noise. A couple of things you can do to help control the noise is make sure your pictures not underexposed, you may need to bump up you exposure compensation a little as long as you don't end up too bright.
You can also try to shoot with the lowest ISO setting your camera has. High ISO = NOISE!
Last you can run your photos through a noise reducing program such as"Noisware" their community edition is free.
PS Contrast settings will do nothing for noise.
May 03, 2011 | Kodak EasyShare Z981 Digital Camera
My Canon Powershot SD880 sometimes takes pictures that have 'ghosts' or litter spots throughout the picture. This happens more often in dark settings and at night. Any ideas?
This is normal behavior when shooting in low light. Just like when someone is speaking softly into the phone, you may turn up the volume on your end. Any background noise, you can now hear more.
Similarly, when there is low light, the camera turns up the amplification on each pixel. Some pixels naturally have a bit more background noise than others, and these show up as bright spots. A higher ISO setting where the camera is more responsive to light is where this occurs.
At a high ISO, taking a picture of pure black shows up as a mottled grey with a few bright spots for pixels that have a lot of noise.
You can overcome this if you have a tripod - set the camera to manual and a use a lower ISO setting. Rotat the selection wheel to M for manual and then press the ISO (just above the function set) button to scroll through different ISO settings.
Photoshop and other programs have noise reduction tools and a tools to remove "hot" spots as well.
Mar 02, 2011 | Canon PowerShot SD880 IS / Digital IXUS...
When i took a picture with my nikon d70 the the outcome is quite bright where to adjust. i'm a beginner
1. You could lower the ISO setting. 2. You could lower the "exposure compensation" setting. It's the button that's half-black/half-white with a plus and minus. There are many other ways but you really should carefully read your instruction manual and experiment.
Oct 29, 2010 | Nikon D70 Body Only Digital Camera
Why does my camera take white pictures outside,
Do you have the ISO set to a very high number instead of "auto ISO"?
Apr 18, 2010 | Kodak EasyShare C763 Digital Camera
My pictures that I take outside are way too bright!
If you have access to the iso menu within the camera,lower the iso 100 if possible.
If you have access to manual controls,
Raise the shutter speed and reduce the aperture to F8
If the camera has a reset setting within the menu, reset the camera to factory default....just in case something has been changed.
Nov 06, 2009 | Cameras
When taking pictures outside bright white photos
i am an train picture guy but neverthe less u cant take anything for granted put cam on "P" and see whad happens and check your manual
Aug 24, 2009 | Olympus FE-220 Digital Camera
Pictures are coming out dark and often can't get it to focus
Having gone over a year without a response to my query, I assume lowering the ISO took care of the grain problem.
Jul 25, 2009 | Nikon D40x Digital Camera
I think my flash is too bright?
Make sure that the exposure compensation is at zero. If that does not work, make sure that the flash is on automatic brightness. Check the manual if you do not know how to do either one of these.
Apr 11, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Pictures are too bright
sir i think this is sutter EV slow or ur AV in lens not operating, u remove ur battery some time.and reset
Mar 04, 2008 | Nikon D40x Digital Camera
LG KU990 Viewty Logo
29 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
