Ac adapter I have a homedics massager which goes on a chair or car seat. The AC adapter is a 120V AC, to 12V DC, 1200mA. The adapter is busted. I am at present in India. Can I use a 220V AC, to 12V DC 1000mA adapter instead Bottom line I think is 100mA against 1200mA
    Problem Solver:
  • 9 Answers
Hi I am an Indian too !
Of course you can use the 220v AC adapter, it will not harm your massager but may only underperform [slow speed, slow vibrations etc]
And be aware that the foreign products you receive, and have adapters rated at 120v are bound to get busted if you use them here in India, don't use them at first place.
Rather, buy an adapter rated for 220-240v for the same output voltage as that of 120v
Posted on Jul 13, 2008
Replacing power supply in a Cuisinart CWC 1600 cooler
Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. his power supply replacement takes about 20 minutes. You need: Philips screw driver, wire cutter and stripper, two 16 gauge wire nuts. That's it.
Dec 01, 2017 | Furniture
Massage chair national real pro 110 volts was put into 220 volt. Where can i see the fuse ?
Search Results
    replacing that AC/DC converter : voltage divider ? ' Electronics ...
    www.electro-tech-online.com/.../replacing-that-ac-dc-converter-voltage-...
    Jan 23, 2012 - 6 posts - ‎4 authors
    we purchased a massage chair from china , shipped to my home . my sister -guided ... being the home electronic "pro" ( lolz i don't know any real **** about ... it into 220vbroke it. i found the fuse to be burned. ... 110v AC inputMissing: national
Dec 14, 2015 | Health & Beauty
Ming an ac/ac adapter model mao-122300
Are you %100 sure it's not 12v DC on the ouput side?
Jun 06, 2012 | Computers & Internet
Mistakenly we kept the homedics massage system in 230v instead of 120v voltage. It's not working now. Is there a way to fix it.
if your Homedics Back Massagers has a product warranty you should bring where you buy it..
if has to warranty you can try some techie sollution.
if it has an adaptor that connected to massagers you can change it with the same specs.
most adaptor has a label that indicates volts amphere and connector polarity..you can buy same specs at ebay.. or search some electronic store.
if it has no adaptor you have to dismantle your massager and search the fuse or circuit connected to
the ac line.. good luck....
Aug 21, 2011 | Homedics Health & Beauty
Wiring poitive and negative
Hi, I have an SBM 500H massage cushion without that AC-DC adaptor... may I know whats the working DC Voltage in Volts and DC Current in amps it works on? Kindly, email me at stycch@yahoo.com... Thanks!
Feb 04, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
