Question about HP Officejet 7210 All-In-One InkJet Printer
FAX MACHINE ON THE FRITZ
MY FAX HAS A MIND OF ITS OWN. WHEN I TRY TO FAX IT SOMETIMES WILL SEND ALLTHE PAGES THROUGH AT ONE TIME. AND SOMETIMES WON'T EVEN GET THAT FAR.
AND THEN THERE ARE TIMES THAT IT WILL SAY "FAX SEND FAILED" BUT YET THE OTHER PARTY RECIEVED THE FAX. AND OTHER TIMES NOT. CAN SOMEONE PLEASE HELP ME OUT HERE. DO I NEED TO USE MY WARRANTY AND HAVE IT LOOKED AT OR CAN IT JUST BE A SIMPLE PROBLEM.
I ALSO WAS WONDERING IF ANYONE KNOWS HOW TO GET THE SCANNER TO ACTUALLY WORK FROM THE BUTTON ON THE PRINTER????
DESPERATE
THANKS
    Scholar:
  • 162 Answers
I would have it checked out. But one problem is it's not receiving a "end of transmission" signal from the receiver. This could be due to line noise, or a dirty line. Do you have DSL and is it running on this line? If so, do you have a DSL filter on it?
Usually you hit scan and go. If that doesn't work, maybe when it was assembled, and when the face plate went down, it pinched the button to be down. Check to see if it clicks when you press it. If smashed, you may need to pry it up and reseat the button panel.
If on warrantee, have it checked out. I do know this model did have issues.
Posted on Jul 25, 2008
Some faxes won't send. Recipient will recieve a partial page and then blank pages. Then my machine will tell me there is a "remote fax error". All other functions work great. I use the phone...
The problem could be to the transmission signal. Try to set your Fax Send Speed to 9600 bps. On your printer operator panel, press Setup > Fax Setup > Dialing and Sending > Max Send Speed > select 9600. Hit Ok to save the setting.
Try to send a fax again to verify that the problem is fixed.
Sep 13, 2011 | Lexmark Prospect Pro205 Wireless...
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
Can not send more than 99 pages as PC fax.
Like every fax machine, there is a limit to how many pages it can keep in memory before needing to be cleared. Yours is apparently only 99. If you want to send more than 99 pages at a time without clearing the memory, i'd look for another printer.
Jun 12, 2009 | Brother MFC-7820N Printer
Pages aren't being sent properly
BUILD UP OF INK ON THE POLLERS AND SOME MACHINE HAVE WHERE YOU CAN SETUP INTERMITTING TIME DELAY INBETWEEN FAXING LETTING THE MACHINE COOL DOWN BETWEEN FAXING AND I HAVE ANOTHER PROGRAM THAT MAY HELP IN THIS MATTER CALL GREENPRINT WORLD.COM
ROD
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Call Sevice 4
reset the unit..press menu#9000*550 Then press start.Call service 3 has something to do with the temperature of the unit check thermostat @ the fuser unit.replace it because the thermostat is not switching to on/off condition although it reaches its peak temperature.
Mar 17, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Faxing additional pages
on the bottom of the machine where you see the check mark it has two arrows, you will have to push one to add pages to send it will allow you to send more than one page at a time. The fax machine should ask if you have another document to sent.
Jan 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
