Question about Nuvo Simplese D 4-Source 4-Zone Audio System System
Nuvo NV-4A Keypad Flashing/Won't Work
One of the 4 keypads for my Nuvo system has the All Off button flashing, and I can't get it to work. The other 3 zones work fine. Is there a way to reset it? Is it a bigger problem? I tried the Lock/Unlock feature, trouble is no one even touched it and it stopped working. All of a sudden it was really loud and the only way I could turn it down was to turn it off using the All Off button, now that button is flashing and the keypad is not responsive. I powered the box on/off, and the keypad lights up momentarily, then goes back to the flashing button. thanks.
  • Anonymous Mar 26, 2009
    in my instalation on all 4 keypads poer on butons are blinking and i cant do nothingt with this
I have the same problem. All keypads blinking in All Off. I changed the fuses on the Nuvo. No luck. Does anyone have a solution to this?
Posted on Oct 12, 2009
My ALL OFF buttons are flashing on ALL 6 of my keypads, when my NUVO is powered ON OR OFF! Flashes under both conditions. Not responsive. Solutions?
Posted on Jul 22, 2012
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Tried holding buttons until light clicked on this should have set the code. It only works when I hold the remote next to the antena. I took the wireless keypad off the wall and did the same thing and it is...
If both the remote and the keypad only work when held next to the antenna you have either interference or a failed logic board. You can tell if you have interference if the small light near the smart/learn button is flashing rapidly. Random flashing is normal.
Nov 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Green light flashing 4 times,sencors lights on,press & hold wall button to open.others wont work
The green light flashing 4 times is sending the code for " Safety reversing sensorsslightly misaligned (dim or flashing LED)". These are the sensors in the doorway. Tweak them a bit.
Aug 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Model 139.53684 Security+ Keyless Entry Garage Door Opener... Green light flashing on door control push button. Remotes no longer work. Can open and close garage door from keypad. Why is light...
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
I programmed 2 new remotes with no issue but, cannot get the remote keypad to reprogram (we just bought the home and don't know the existing code) the model for the garage door opener is Chamberlain...
Your keypad may be bad. If you press and immediately release the smart/learn button and then key in your 4 digit code and press enter the keypad should be working. Be sure you have a good battery. Actually the flashing of the keypad is indicating that it is sending the signal to the receiver. Holding the enter button in doesn't do anything extra.
Nov 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nuvo Essentia system on/off button flashes when keypad is plugged in. I can get 1 port in the back of the EZ Port to work on all zones but when keypads are plugged into other ports on/off button just...
You may have a pair of the cat-5 wires in the incorrect order which is causing a combus fault. Check all your cat-5 connections, ensure they are T568a (GS/G/OS/B/BS/O/BrS/Br).
Let me know if that checks out and we will continue trouble shooting.
Thanks,
Oct 29, 2009 | Nuvo Essentia Amplifier
I have nuvo 4 zone switch that I cannot get to
That indicated there is a short or incorrect wiring on the combus of the keypads.
Remove the keypads from the walls and unplug them one at a time.
Then unplug one at a time from the all-port until it works.
The last one you unplug will be the offender, inspect the cat-5 crimp for a pair or wires that are in the incorrect order.
Cheers!
Jul 19, 2009 | Nuvo Simplese D 4-Source 4-Zone Audio...
Whirlpool Dishwasher Model GU2500XTPS1 Light on soak/scour button flashes on and off. Dishwasher will not run.
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
2. Check/replace control
Nov 03, 2008 | Whirlpool Dishwashers
Clock is flashing - no other buttons will work
hi
it sound like the keypad has died does happan on sharps does the light come on when you open the door ,onother problem that can happen is if one of the microswitches is sticking from storage ,if they are not working in sync then the keypad won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Nuvo Simplese D 4-Source 4-Zone Audio System System Logo
1,050 people viewed this question
Top Nuvo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Nuvo Audio Player and Recorder Expert? Answer questions, earn points and help others
