Question about Whirlpool GU2400XTP Built-in Dishwasher
How do I open the sprary arm
My dishwasher is not cleaning the top rack. Each time the repair-person shows up they open the spray arm at the bottom, and clean the assembly underneath.
However, I am not able to open the spray arm assembly -- its seems screwed in with some kind of plastic screw in the middle -- that won't budge. Any advice on how to get it open?
The plastic screw is not holding it down. First disconnect the white tube in the back of the bottom spray arm.Now turn the stub part clockwise. and the spray arm should pop off...
Posted on Aug 27, 2008
-+the top arm is not turning in my washer Model #GU1200XTLB2. I have removed it and cleaned it and it is still not turning. Can you offer any suggestions? Thank you,
Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
homeguides.sfgate.com > Foreclosures > Other Foreclosures
Remove the lower tray of the dishwasher to freely access the spray arm. ... Although spray arms are directly powered by the water pump for the dishwasher, not all of ...For best use, clean the filter and pump at least a couple of times per year. .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell Your ...
Dishwasher Cleaning - Top Rack Doesn't Clean - YouTube
? 12:57
https://www.youtube.com/watch?v=75DB9cyPYO0
Feb 7, 2013 - Uploaded by Dogwood Tales
With that said, I'm working on more such videos for household maintenance and repairs and ... In my case the bottom rack of thedishwasher was cleaning well, but the top rack of thedishwasher was not coming out clean at all. In fact ..... How to clean and replace Dishwasher Spray Arms - Duration: 2:07.
How To Fix A Dishwasher Not Cleaning Bottom Or Top Rack ...
Jan 12, 2016 | Dishwashers
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
Bottom rack cleans fine, top rack doesn't clean at all - can I take apart the top spray arm?
yes, the spray arm can be removed and cleaned out.
Also, clean the 3rd (very top spray area) located attached to the top of the dishwasher. You want to make sure this small (1 inch size) piece can spin freely, so water can rinse the upper rack items.
Feb 01, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
The dishes on the top are not getting clean what can be the trouble? Tea stains and grit are left in cups and glasses.
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Dishwasher not cleaning dishes
Aug 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Top water injector not working
Aug 24, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Spray arms do not turn. water to them but not
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
Our dishwasher is type no:575-0, model:665.17369301.dishes r not getting clean properly.
This may help you.
Aug 22, 2009 | Dishwashers
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Only washing top rack
After observing the water just gushing out when the spray arm was removed, we determined there was still a bunch more calcification/soap in the ends of the spray arm. (We have very hard water in our area). Unfortunately, you cannot open up the spray arms to clean them out, so it took about 30 minutes of pounding and manipulating to get all the gunk out. Now my dishes are clean again. Hallelujeh! And the water cleaning the dishes is cleaner, as well.
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
103 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
