Question about JVC MX-D401T Shelf System
Troubleshoot auxiliary equipment
I have connected a turntable as auxiliary equipment to my JVC MX-D401T system and get no response. Everything works but I get no sound. I have tried 2 different turntables with no luck. Any solutions?
  • goatler1 Apr 04, 2009
    Thanks. I have already hooked up an amplifier and everything works perfectly now. I appreciate the info though.
    Brigadier General:
  • 8,546 Answers
There is no Phono input on your JVC.
What TT are you trying to hook up? If it's a traditional one you would need a preamplifier to boost the tiny signal from the cartridge to a suitable level for the AUX to use.
If you have an old traditional receiver with a Phono section hanging around you could rig something up between it and your JVC.
Plug the TT into Phono on the old receiver. Run RCA cables from any Tape REC output to the AUX. Done.
Posted on Apr 04, 2009
Can i connect a turntable to a JVC RX-5020VBK receiver?
With a bit of effort: This receiver has a variety of auxiliary or "line" level audio inputs (CD, VCR, etc.) but none designed for a phono cartridge input. You would need an external phono preamplifier in between the turntable output and one of the JVC inputs to have sufficient audio level. (Some newer turntables come equipped with such a preamp, but most do not.) They cost from $20 to $50 from a variety of suppliers (MCM, Parts-Express, etc.)
Dec 29, 2016 | JVC Audio Players & Recorders
JVC MX-GT80 CD Shelf System
Yes, it probably is.
No.
Sometimes.
Press the correct button - the one on the left and slightly up from the big one.
75W on a good day.
[These are vague answers in response your your equally vague question. Enjoy!]
Oct 17, 2014 | JVC MX-GT88 CD Shelf System
Why speaker hum when connecting preamp out cable to Receiver
An audio hum like you are describing is usually from a bad wire or connection. It could be a filter capacitor from a power supply too. Try other cables to see if that helps.
Jul 05, 2014 | JVC MX-D401T Shelf System
I want the number r-924 resistor thank you.jvc ca-d401t
do you want the value of that resistor?
can you see the colour bands on the resistor?
there could be 4, 5 or 6 colours on it
if you can tell me the colours in order
May 09, 2010 | JVC MX-D301T Shelf System
It doesnt recognise cds
There are a few possible causes. 1. Lens on laser pickups dirty. 2. The belt that closes the drawer also lifts the CD assembly to allow disc to spin. If the belt is loose, drawer may close but not be able to lift CD. Listen to mechanism after drawer closes. Do you hear the disc spinning up? or Do you hear a motor trying and then shutting off? You can also remove the case top and visually check these. 3. The spindle height may have slipped. 4. The focus and tracking may have changed with age. 5. The pickup may be bad. And finally the carriage may be stuck and not moving the Pickup(Laser Assembly) to its start position.
Jul 17, 2009 | JVC MX-D401T Shelf System
Auxiliary audio input for 2008 Mazda MX-5 with Bose sound system
Yes you can add auxiliary or ipod interface also xm radio
go here for more information
http://www.oemautosound.com/c-161-mazda-products.aspx
Jun 30, 2009 | 2008 Mazda Mx 5 Miata
Jvc mx-gc5
Yep, as I suspected, the STK412-430 needs to be replaced. That is the most common failure part. Try replacing that and your problem should be resolved.
Dan
Sep 08, 2008 | JVC MX-GC5 CD Shelf System
Speakers
Your system not being a real powerhouse to begin with, I'd find the most efficient speakers available (read: small) and cable each channel like the picture near the bottom of this link...
http://wolfstone.halloweenhost.com/Audio/audcon_ConnectingAudio.html
The two points at the left are your speaker terminals. Plus on top, Minus below.
Apr 25, 2008 | JVC MX-D401T Shelf System
185 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
