I have just got my laptop connected to wireless with a router. There are 2 more laptops in my households I want to connect to the same router but it wont let me, saying Windows cant connect to network on one laptop and the other one says it is restricted and that I am giving the wrong Network Key. So Im stucked and dont know what to do! Can you please help me? Kind regards Annika
  • 52 Answers
Check the internet settings, the settings must not allow multiple connection.
Posted on Jul 12, 2008
Hi there, I'm having an issues with my HP Pavilion 15-n008TX in which the wireless connection keeps flickering on and off. No other computers in my household are having this issue. This is a brand new...
try turning your router off and on again, then maybe change the Channell that your router is broadcasting on, you will need to access the router with a user name and password, the setting is in the wireless settings. try Inssider on a windows laptop to see where is the best chan you will need.
Oct 07, 2013 | Computers & Internet
I am housesitting and want to connect my wireless laptop to the household internet. There is a D-Link DSL-3001 ADSL Ethernet Modem. There is no wireless available in the home. How do I connect please?
Unless you happen to have a wireless AP or router that you can plug into the modem you will need to pull the ethernet cable that runs from the modem to their computer and plug that into the ethernet jack on your laptop. Even though your laptop is capable of wireless it should still have an ethernet jack available to you.
These would be the only ways to get a connection to your computer.
I hope this helps! If this did help you, please give a thumbs up!
Jun 28, 2011 | D-Link Computers & Internet
My Dell laptop does not connect easily to d-link WBR 2310 router
2 wireless laptops are connecting. that means the router must be working properly. Only 1 laptop is not connecting.
Try to change the wireless channel on the router.
For this you will need to open the set up page of the router.
Is there any computer connected to the router ? If not then you will need to connect the computer to the router and open the set up page. Under wireless settings try to change the wireless channel on the router and see if that works.
Apr 16, 2010 | D-Link Computers & Internet
Hi I hope you can help. I set up my router it was working fine wirelessly. The problem is now that I can only connect to the internet by connecting my laptop directly to the wireless router. It the same...
If that is the case changing the wireless settings of the router like the SSID and channel will be able to fix it by accessing the router setup page, but I strongly suggest you just reset the router by pressing the reset button for 10 seconds and then after that reconfigure it back that should fix it...........
Oct 18, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
2wire portal router, after year of wireless connect, stopped
it could be that the wireless part of the unit has failed but to test, can you make sure and try while sitting very close? Also, check for any new appliances close by causing interference
Jul 08, 2009 | 2wire HomePortal® 1800HW Router...
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
I cannot connect a new lap top to our wireless router
There's no special settings actually in adding another notebook to your wireless network. You can add up to 32 wireless clients on your wireless network. You will see a wireless network icon at the system tray by the clock, just click that and you will see the list of available networks. Choose your network and click connect. That should do it.
Nov 30, 2008 | Linksys Wireless-G Broadband Router
Can I piggyback a wireless router onto a hard-wired router?
Yes, you can connect the DI-624 to your exitsing EBR-2310, you just need to connect the a cable from port 4 of the EBR-2310 to the internet/wan port of the DI-624, then after that you can already use now the wireless to your laptop and also the wired router to your desktops.
But I may suggest you to just replace the EBR-2310 with the DI-624 so you will only be using 1 router that can cater your laptop and also your desktop, Just connect the cable from your modem that is conencted now to your EBR-2310 to the internet/wan port of the DI-624 then run the setup CD that should be it.
Hope that helps...........
Aug 30, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless Adaptor Fault
Dear plz check wheather your ssid is correct or not, then check you have security key,plz retype the security key, if still not slove then just remove your wireless dirvers and reinstall it will be fine,
Dec 16, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
