I am having trouble with my computer called a stop error and it stops and shuts down my computer how do i get it to stop doing this?????
  • 3 Answers
Just let me know whether u can login or not (Windows) then only some suggestion can be given.
Posted on Jul 12, 2008
Blue screen unable to restart windows10
A stop error (also called a "blue screen" error) can occur if a problem causes your PC to shut down or restart unexpectedly. When you experience this type of error, you won't be able to see things like the Start menu or the taskbar on the screen when your PC is turned on. Instead you might see a blue screen with a message that your PC ran into a problem and needs to restart.
If you see a stop error while you are upgrading to Windows 10, setup will automatically go back to your previous version of Windows.
If the error continues, try to fix it by removing software or hardware.
Sep 22, 2017 | Blue Computers & Internet
Dishwasher won't stop running
Question what do you mean not stop running. Is it starting the pump and then shutting down like a leak error then restarting or always on. If always on then you may have a bad main board with a stuck relay. I would call Samsung with this issue. But if it is starts stops then starts you may have a leak then either take unit out and find leaking problem or like I said before call 1800 Samsung for there products.
Mar 14, 2014 | Dishwashers
At startup windows narator give error 0xc000007b
If you have installed a network card, uninstall any software you installed for it, then shut down your PC. Uninstall the network device you are having trouble with and boot your computer into safe mode (Power up the computer and IMMEDIATELY begin to tap the F8 key SLOWLY about ONCE PER SECOND until you see a menu, then STOP. Use arrow keys to select safe mode then press enter) to see if it will start correctly. If windows starts in safe mode, the reboot. If windows starts normally, there may be a problem with the driver software (download new drivers) or the card itself is bad, and windows chokes on it. You may wish to try and install it again, but that is your call. I would try a different adapter.
Sep 16, 2013 | Acer Computers & Internet
This computer has Windows XP freshly loaded with all Service Packs. Occasionally the boot up process stops at the Dragon flash screen. Then I shut off the computer, wait a few hours. Then it may boot up...
If your CMOS battery is not retaining your system setting you will see this problem...One way to know if this your problem is to go into setup and check the system time, also stopping at the Flash screen
it could be waiting for user input...You could try changing your setting from stop on error to not stop
on error
Feb 08, 2011 | Soyo KT600 Dragon Plus Motherboard
What shld i do if asus laptop is in zzz mode and it wont turn on?
Try this simple solution- press on the power button for a very long time, until the laptop stops working.
After the computer shuts down, turn it on again and look for the sleep settings, sometimes the computer is too eager to turn off the display. You'd be surprised how many computers have troubles waking from their sleep (maybe they need to call the charming prince). Anyhow, check the settings for the computer's sleep. I always ensure that my laptop won't independently fall asleep, always by button.
Nov 05, 2009 | ASUS Computers & Internet
Biz Hub c250 gives error code 3452
C3452: Pressure Heater Trouble.
Try to reset it like this:
Shut down from the main power switch (the one behind the front cover).
Keep pressed the Utility/Counter button.
Power on while the button is kept pushed.
Release the 'Utility/Counter' button only when you see the 'Trouble Reset' button on the touch screen.
Touch the 'Trouble Reset' button, a small ok should pop up underneath.
Power off, wait for a few seconds and then power on.
Jul 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
May 11, 2009 | Computers & Internet
Problem with computer shut down when using Maplestory & other P2P games
try to uninstall all security softwares and just install the most reliable one. That should fix your problem.
Hope this helps.
Thanks,
Karlox™
Jun 11, 2008 | Computers & Internet
Downloading game
If you are trying to download that game online it may be the effect of virus or your system configuration may not be compatible with that game. If it is a virus first remove that virus and then download game .
Feb 12, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
