Question about Ecoquest Fresh Air Air Purifier
Fresh Air Maachine by Ecoquest
The mesage says SynAir G4 Replace Plate.. I haveput new plate in and the mesagfe is still there and it won't let me adjust the purifier settings...will run but there is no ozone smell and the message will not go away ....What can I do
  • dirtman1024 Jul 12, 2008
    I have cleaned the machince..put a new plate in and pressed the reset button and it still does not work...What now and dose anyone know what the cost would be if I have to send it in for repair
  • 2,794 Answers
I've read from some other posts on here that Ecoquest is good about returning the items and replacing them.
Posted on Jul 12, 2008
  • 19,396 Answers
The UV lamp needs to bereplaced. Call the manufacturer using the phone number at the end of the user manual. Ecoquest will take the machine for repairs or send you a replacement lamp. If you do not find customer service number use the contact in
EcoQuest wbsite.Regards
  • Ginko
    Ginko Jul 12, 2008
    Note replacement parts UV lamp and starter capacitor kit cost about $40.
    Genius:
  • 3,422 Answers
HI,
The only solution to fix this problem is to get it repaired.there are no home remedies.But you can try cleaning the plate.
  • 1 more comment
  • Priya darshan Jul 12, 2008
    If you need anymore help let me know..
    Remove the plate, and clean it with ammonia and water and let it dry for 24 hrs.
    And also on the front there is a reset button next to the power button push that to reset cleaning cycle.
    These are few troubleshooting steps you can try to fix this.If this doesn't fix your problem then you will have to get it repaired.
  • 2,427 Answers
Try this before sending it in for repairs
1.) unplug it
2.) press and hold the power button(turn it on)
3.) plug it back in
4.) press reset then release
5.) turn of unplug
6.) press and hold reset
7.) plug it back in
8.) turn it on then release reset
Ecoquest fresh air not omitting ozone
Did you clean the plate contacts with alcohol? How old is the plate? Is the glue that holds the grid in place turning brown? If it is, it may need to be replaced. Call (336) 499-2505 and ask for free email supplemental cleaning instructions before you do anything else. The instructions may help you solve the problem.
Jun 14, 2012 | Ecoquest Fresh Air Air Purifier
Fresh Air: Replace the plate
I found this link to get parts for it:
airpurifierrepair.com
Ecoquest can support the product for you as well regardless of who you bought it from.
Oct 06, 2008 | Ecoquest Fresh Air Air Purifier
How long do Ecoquest purifier plates last?
The "Replace Plate" message comes on for more than just the plate. Is the fan still running when it displays (Replace Plate"? The squeaking noise would be coming from the fan. I don't know what all it works for. It does display when the plate contacts are dirty, when a wire to the plates is loose or corroded, when the bulb is bad or loose and when the ozone generator quits. I have encountered all of those. Plates should last a couple of years, depending what's going on in the indoor environment. Before you go any farther, call (336) 499-2505 - they give away information and will help you solve your specific problem.
Jun 11, 2012 | Ecoquest Fresh Air Air Purifier
Perform cleaning on EcoQuest Fresh Air won't go away after pushing reset button
If you did not thoroughly clean the contacts for the ozone plate, the "Perform Cleaning" light will not reset.
May 05, 2012 | Ecoquest Fresh Air Air Purifier
Is it possible to obtain an owners manual for the Ecoquest Fresh Air-Model Fresh Air 2.0? Intelliair SynAir G? We purchased a used one, biut need manual for proper cleaning instuctions.
The link below is to the EcoQuest Fresh Air manual. It doesn't specify model #'s but should provide you with the information to clean your unit. Thank you for using Fixya!
Greg
Ecoquest Fresh Air Manual
Jan 11, 2012 | Sharper Image Air Purifiers
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
I have a "fresh air" and I'm receiving a message saying synair- G4 replace lamp. Does this mean only to replace UV lamp
This means that the UV lamp has stopped working. Since you need a good starter to make the lamp work, it make sense to replace both at the same time.
Feb 04, 2010 | Ecoquest Fresh Air Air Purifier
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Jun 03, 2009 | Ecoquest Fresh Air Air Purifier
I have a Fresh Air Unit from Ecoquest. The
When that message appears the plate does not make good contact with the two contact points. You can use rubbing alcohol and a q-tip to clean the points. After 1-2 years it is also advisable to change the purifier plate. Plates are about $15 and can be purchased at EcoQuest.com
If the plate is dirty (and this can unnoticeable grime-grease) clean the plate with 1 part clear ammonia and 1 part water. An old tooth brush works great.
Dutch
Apr 16, 2009 | Ecoquest Fresh Air Air Purifier
Ecoquest Fresh Air Air Purifier Logo
352 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
