Amana ptac will not work on any setting except FAN
I have an Amana PTAC model PTF153A50AA. Recently it starting kicking out after running for several hours. Now it will not come on except on the fan setting. Could this be the thermostat? I can't hear it clicking anymore when I move it.
  • elpow Aug 04, 2008
    I have the same model a/c. Mine hasn't cut out yet, but it's making ominous noises and leaking just like a different model I used to have did before it cut out. Is there anything I can do to fix the a/c before it loses cooling power?
oscarn
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
SOURCE: Zoneline PTAC short circuit
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Posted on Mar 30, 2008
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 26 Answers
SOURCE: Remote Thermostat
call the amana dealer nearest to you order one
Posted on Nov 27, 2008
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
What does it mean when it indicates stop?
Wow, a talking AC?
How to Reset an Amana PTAC - YouTube
? 0:55
www.youtube.com/watch?v=D4SQfFChiKY
Mar 28, 2014 - Uploaded by Total Home Supply If you ever need to reset your Amana PTAC this simple guide will ... HVAC AC Blower not working, troubleshooting Fan Control board, Fan not ...
Aug 21, 2015 | Amana Heating & Cooling
Where can I find a troubleshooting manual for the DS01E amana t-sta?
http://www.amana-ptac.com/Portals/3/PTAC/PDF/DigiSmart%20DT%20DS%20DD%20Wireless%20EMS%20Installation%20Instructions%202010.pdf
Feb 19, 2015 | Amana DS01E - DigiStat Thermostat with...
If you unplug an Amana PTAC unit and it freezes what could happen?
If you are not going to run the unit put a large bag over the out door section. The unit will be just fine.
Jun 08, 2017 | Heating & Cooling
I need a manual for a Amana PTAC model PTH123A35AC. I been looking for one & just can't find it. Please any suggestions, thanks.
Here's a good place to start: http://www.h-mac.com/brands/cooling-brands/amana.html
The Amana PTAC PTH123A35AC is obsolete and replaced by the Amana PTH123E35AXXX. The literature is similar. Search out your model # and than visit the "literature" tab to find everything's that available. Everything from service manuals to parts manuals. Good luck!
Aug 27, 2012 | Heating & Cooling
My Trane PTAC unit has a problem with the compressor kicking on, fan runs, clicking noise like it is trying to kick on, but takes a good 15 minutes set at a low temp. setting for it to finally engage.
The compressor start capacitor is bad...it is not giving enough "kick" to get the motor running...
at least it is a good idea to change this first because if this does not work then the compressor needs to be changed out...
heatman101
Apr 01, 2011 | Heating & Cooling
House wont cool ..tried to reset breaker in fuse box and breaker outside...this unit is only just over a yr old . the fan thing outdoors is not kicking on..
Does this unit have 2 breakers to it? The model you put down is a PTAC and generally just plugs in to the wall so it would have only 1 breaker. If I recall correctly it's got a 5 year warranty on parts so it may be worth it to check with your local HVAC tech and have them do a diagnostic for you. A good place to start would be Amana who can tell you the authorized service company in your area. They'll get the part for free and should roll the diag fee into the repair cost so you'll only pay for labor (if it even needs a part). Their sales and service number is: 1-800-647-2982. Here's a link to your warranty info:
http://www.amana-ptac.com/Home/Warranty/tabid/449/Default.aspx
May 27, 2010 | Amana PTH123B25AJ Heat Pump Air...
Ptac fan keeps blowing
May 02, 2007 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
