SOURCE: my phillips 5.1 dvd player not playing dvd disc, only playing vcd
the laser lens on the optical pickup is dirty or scratched. to clean: buy a disk cleaner and use it per instructions. if it doesn't help, you can do it manually. remove the top, remove the top off of the disk assembly (you may have to remove the whole assembly first) until you see the lens. be careful with the cables and wires. use a lint-free swab (not a q-tip and not your finger), gently wipe off the lens. replace the covers and test. if it still doesn't work, it may be scratched or damaged. in which case, it needs to be replaced.
SOURCE: playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
