Question about SanDisk Sansa Clip MP3 Player
Stuck in FM mode
When I use the FM on my Sandisk MP3 Clip it gets stuck in this mode and to get it back to play recorded music I have to re-connect it to the computer and go through putting it on and off.
Please help
  • hpewtsk Jul 15, 2008
    my sansa display have went out and I can't get it back to the music list besause I can't see what I am doing please help me
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
I have a small new Philips Music system which plays CD as well as FM. It is brought from Poland with a guarantee last month. The problem is that CD'S get stuck after about 25 minutes of playing. ...
Did you get a small piece of single wire with the system. That's the FM antenna. Connect that at the back of the music system labeled FM Ant: and it should solve your problem. Just check in the auto tune mode does the radio stop at the station number correctly and if the stereo indicator light up.
When the player gets stuck, if you put another CD will it play the new CD play for 25 minutes ?. If so try playing the last track of a CD after a cold start. It it does not play the last track on a cold start , you have some physical blockage/damage on the lens rail after half position.
Mar 07, 2011 | Philips Audio Players & Recorders
How do I record FM radio programs and transfer them to my computer?
unfortunately, the voice recorder works only as voice recorder, it cannot play FM and record it at the same time. though you can play fm radio from another device and record it using your SanDisk mp3 player.
To transfer your recordings from your mp3 player, connect your device to your PC.
Open "My computer" from your PC and you'll there "your Sansa Player"
Double-click on "your Sansa Player", then open the "Music" folder, then, open "Recordings" folder.
You'll find all your recordings on that folder.
May 14, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip has crashed. No response when I try to reset
Press the Power and Play (>||) button together for 20 seconds to reset the unit!
Nov 29, 2009 | SanDisk Sansa Clip MP3 Player
I have a sansa clip and I can;t get it out of the radio mode and back to playing my music/books. I have tried holding the power button for 20 seconds multiple times
Do you know how to get to in main menu? using menu button - the small button under screen, on the right. After you press that button, you can see "FM Radio" with a picture, use up/down button to get into Music options.
Good luck
Nov 19, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip is stuck on radio, re-setting does not work,
Can you see your screen? If not turn on your player and press the home button. Press up once and play 2 maybe 3 times to get it back on your whole playlist section. It should start playing music then.
Sep 25, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip audio when playing songs ...FM audio fine
the mp3 audio driver may be missing and system needs to be updated.
Jul 09, 2009 | SanDisk Sansa Clip MP3 Player
The sansa clip mp3 player has totally frozen up-stuck on fm radio
Press the Home button and see if it will go to the settings menu. If it will, change the USB Mode to Auto. If it won't, hold in the power on/off button for 15 seconds to reset the player, and try again.
-Tha Mp3 Doctor
Feb 11, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip Stuck in FM mode - Won't go into music menu
Press the little button that looks like a house to go back to main menu
Aug 13, 2008 | SanDisk Sansa Clip MP3 Player
Getting Out Of F.M. Mode
use the button that looks like a house on the front of the player
Aug 03, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
