Question about Hoover Washing Machines
I was moving my Hoover hnl6126 wshing machine and forgot o unplug it from socket, as it came forward the lead was overstrecthed and there was a popping noise and a flash from inside the machine. I'm thinking that an internal fuse has blown. Can i replace this myself? If so how? Do you think that is what has happend?
  • 1,462 Answers
No internal fuse. possibly the lead come away from the input connection on the suppressor capacitor. take the top off and have a look
Posted on Jul 12, 2008
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Table saw stopped running. Will run when I tilt it forward
The fact that it runs in one position but not in another tells me that you have an electrical problem. Specifically, it suggests that you have an intermittently broken circuit that opens and closes as the position of a wire or relay is moved by gravity. However, it could also mean you have a short if a bare hot wire touches bare metal as your changing the position of the saw. If that's the case, then you'd probably see and hear some electrical arcing--one heck of a spark--when the motor stops running.
So let's assume it's an open. If you know how to use an ohmmeter, you can easily find the break and then replace the damaged part. If not, you could first begin by unplugging the power cord, removing the blade, plugging the power cord back into the wall socket, and hitting the power switch with the saw in the level (not working) position. Then start manipulating the power cord from the wall socket to the on-off switch--move it back and forth and up and down to see if one of the wires in it is broken but the broken ends can be put back into contact by these movements. If the motor starts to turn during these manipulations, replace or reattach the power cord. If nothing happens, unplug it and examine the leads from the switch to the motor to see if they're firmly attached at both ends. If one of the leads is loose, reattach it. If they look good, plug it back in and manipulate these leads one at a time like you did the power cord. It would be a good idea to be wearing some heavy insulated gloves during this procedure. If the motor starts to run, replace the damaged lead. If nothing happens, then temporarily wire around the on-off switch to see if it's damaged. If the motor runs when you do this, replace the switch.
Again, it would be far better to try to find the location of the open circuit using an ohmmeter with the power cord unplugged. If you don't have an ohmmeter, consider buying one. They're not expensive and not difficult to learn to use.
Good luck.
Oct 29, 2014 | Saws
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Hoover error codes
Ben, the simplest solution would be to unplug the machine from the wall socket, wait 5 minutes plug it back in and see if that clears the error code.
Jan 29, 2014 | Hoover H160E Front Load Washer
Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Feb 12, 2010 | Washing Machines
Wshing machine operates but does not rinse and speen.
Try cleaning the filter if its not pumping out water this causes no rinse / spin
Oct 02, 2009 | Washing Machines
Hoover Elite motor runs when moving backwards but not forward
Are you sure its not just your belt on the beater of head slipping and needs to be replaced?
Oct 18, 2008 | Hoover Elite Rewind Bagless Upright...
Intermmittent buzzing noise
May 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Hoover VHD Washing machine
Surely it is the wall socket.
Mar 19, 2008 | Washing Machines
Opening the top of a wshing machine
you either have 2 screws in the front of the console or on the back of the console. remove these 2 screws and the console flips up. under that youll see 2 brass looking clips one on the right one on the left. remove thoughs clips. unplug the wire that are hooked into the top of washer. the whole cabnet tilts forward to be removed. look under cabnet youll see the switch
Nov 25, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
121 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
