Question about Microsoft Windows 98 for PC
Windows 98- always starting in safe mode - Microsoft Windows 98 for PC
    Scholar:
  • 58 Answers
Hi.
The reason of of start in safe mode is to give you the opportunity to fix something wrong in your system.
Posible causes :
- You are not shuting the system down Properly.
If you have a power supply that needs to be turned off manually make sure you turn it off only when the system tells you it is save to do it.( after clicking in shutdown in start menu).
- There are incompatibilities in your system.
Make sure all the devices are properly installed ( hardware and software) and and there is no conflict between them.( you can read about this in windows help( look in start menu or in the toolbar of any window for the button HELP).
Some times it is a simple driver you need to install or reinstall.
- A system file is corrupted ( most the time you will have to reinstall Windows) if that is the case, there are other ways to fix it but are a little more complex.
- Problems in the Registry( only people familliar with that can fix it) or can be solved by reinstalling Windows.
-Make sure the CMOS is saving your Config in the setup.
may be the battery needs to be replaced( you will have to configure Setup again after replacing it.
In any case i advice you to get help from somebody familiar with PCs, before you try anything that can result in damage for your PC.
If you want to do it yourself, get some tutorials about PCs.
Hope this help.
Regards
Posted on Jul 12, 2008
Error code id ox8cccooo
The blue screen of death? Have you tried starting in safe mode? Shut the system down and when you restart push f8 and hold. That will give you several options, just try starting in safe mode and doing a disk clean up.
Mar 24, 2014 | Microsoft Windows 98 for PC
IBM Thinkpad R60 - how to run in safe mode
When it is starting up at the Splash Screen(windows logo screen) hold the power button in to shut it off this should bring up the menu to open in safe mode. Might take a couple trys.
Jun 21, 2013 | IBM ThinkPad Computers & Internet
Hp Vectra 6VL will only start in safe mode
Run the computer in safe mode and then go and shut down unnecessary startup programs, then restart the PC.
Dec 23, 2012 | HP Vectra VL420 PC Desktop
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Always show windows normal start mode and starts not,I can not also go to safe mode
while booting press F8 button repeatedly.
there a option menu comes in dos mode.
select your option (safe mode) by arroy key and then press enter key.
your computer will start in safe mode.
Feb 18, 2010 | Microsoft Windows XP Professional With...
Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
May 09, 2009 | Computers & Internet
I have a problem to install window 98 .
Another solution is to download and install Microsoft Virtual PC in XP, create a Virtual PC drive, and install Windows 98 onto the Virtual PC drive. This works fine if you want to run Win 9X programs which don't require access to USB ports on your computer. If you need Windows 98 to have full access to all of the computer hardware, then use palaboy's solution.
Apr 21, 2009 | APC USB Port Version For Windows 98...
Desktop PC with Windows 98 OS won't boot up.''windows protection
if you reload windows you will lose all of your files...try system restore from the command line in safe mode ...In SAFE MODE>START>RUN type MSCONFIG and enter in the general tab on the bottom there should be LAUNCH SYSTEM RESTORE
Apr 15, 2009 | Computers & Internet
I am using windows 98 .when ever i start my computers it is showing error A FATAL EXCEPTION 0E HAS OCCURED AT 016F:BFF8D18A AND COMPUTER REBOOT AGAIN PLEASE GIVE ME SOME SOLUTION.
Sounds to me that a program installed isn't playing nice with Windows 98. I would go into safe mode and remove what ever software was recently installed or do as the link says and remove Antivirus program. If you can't get into safe mode I would have to tell you to reinstall Windows 98.
Have a good day,
ArmyMason
Feb 26, 2009 | Microsoft Windows 98 for PC
My pc starting problem
You can try starting win98 in safe mode, keep shift key pressed on startup to force safe mode. Then, If you can start in safe mode you may try to troubleshoot the problem uninstalling software recently installed, looking for devices that are not working properly in device menager, and eventually performing a virus scan and a system check using Norton utilities or a similar program. If the PC doesnt even start in safe mode I suggest re-installing the system from Win98 CD.
Hope this may help
Feb 14, 2008 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
79 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
