Question about Rockford Fosgate P3001 Car Audio Amplifier
Amp clickin in and out
Yes u just gave me some adivice about my amp clickin in and out i ran the remote straight to my fuse box so it got constant power just to see if it still did it and it fixed it but i dunno i dont want to burn my amp up what u think
  • 1,498 Answers
As long as there is power to the Remote terminal, the amp is on.
If the rest of the system is off, the amp probably won't suffer, but why take a chance. Also, it will drain your battery overnight.
Put a switch in there somewhere. Make sure you can cut the power.
Great job on the click fix.
This does change my view of your original problem though.
Your description covered every symptom of power starvation.
The Remote is the amps 'On' switch.
Put +12v to the Remote, the amp turns on.
It's how the head communicates with the amp.
If the head units Remote Out was experiencing either an intermittant connection to the amp (loose wire, intermittant short) or power fluxuations of it's own, that would produce symptoms similar to power starvation (clicking off, coming right back on). Only it would be random.
Your Bass vs. Volume observations would also have been random. They weren't. You were able to reproduce the problem at will.
You probably have a multimeter handy.
Since running a hot lead to the remote terminal on your amp stopped the constant 'restarting', the next step is checking the Remote wire (condition and voltage) going from the head to the amp.
Start at the amp. Connect the negative lead to a ground. Connect the positive lead to the remote wire coming from the head unit. I assume you disconnected it from the amp. It shouldn't matter.
When the head is on, it should be +12v.
With the meter still connected, slowly turn up the bass.
Then the volume. The voltage should remain constant no matter what.
This has been mostly FYI.
Rule #1: If it ain't broke, don't fixit.
Feel free to contact me with any other questions, problems or just to show off.
Great job
Posted on Jul 12, 2008
I wired a 1200 watt amp kit with a 2x 12 inch box set. I have checked the fuses and they are fine. There is no power. What do I need to check next.
if the power wire is ran to the battery an none of the fuses are bad , check ur ground wire make shore its get good ground an if thatdont work take apart the amp an see if the wire are connected to where ur power goes an the fuses
Jun 19, 2011 | xXx XA10002 Car Amp
I bought a brand new fuel pump and now im hearin a clickin sound from da hood where da fuel pump fuse at or is it the relay and my car start sometimes
Most likely it is the fuel pump relay. It is located in the high amp fuse box under the hood and there should be a diagram on the fuse box cover or inside the fuse box itself.
Feb 20, 2011 | 1999 Mercury Grand Marquis
Xterra car quit running. had no spark @ distributor. replaced crank sensor and got spark. no gas pressure. replaced fuel pump, new one do not work. no power to it. checked fuses/relays, no luck. ran...
the fuel pump fuse is fuse #1 15amp in the inside fuse box ( left side of dash behind fuse box cover ) the fuel pump relay is behind left side of dash ------- cavity #2 & #5 at the relay should have battery voltage in start and run cavity # 3 is the power out to fuel pump and cavity #1 is the ground that is turned on by the on board commputer.
Jan 15, 2011 | Nissan Xterra Cars & Trucks
My amp i just instaled is a terminater mtx 250 watt amp and the lights are flashing instead of a constant red i checked my power and ground what else would it be
Check your remote wire on both the deck and amp... If the remote wire is loose it will turn the amp on and off constantly... Also check to make sure that the fuses on the amp it self are properly seated.
Oct 30, 2010 | MTX Car Audio & Video
How to hook up my amp?
first what are u trying to push, second, the amp is 150w rms. that mean constant power, and 250 @ 2 ohms, now you have power, gnd=ground, and remote<- that turns the amp on when you turn on the car, power or the + sign is what gets connected to the battery, then the ground/gnd or - sign is what gets screwed to the metal of the car, then there is the remote this wire gets connected to your radio, or to any accessory fuse, i.e. lighter, radio fuse, or if you have an aftermarket radio, then it gets connected to the blue with white stripe wire, that will be the amp turn on wire.
You will need red wire about 17ft, black wire about 1ft, and 15 to 16 ft of remote wire, or you can just by an amp kit, that will be easier.
now that the amp is done, time to do the speakers;
You have + and - on the amp, and your speakers have the same signs as well, just make sure when you wire the speakers + goes to + and - goes to -. if you need more help call me @ 6314330567
Feb 19, 2010 | Car Audio & Video
Sony Xplod amp no longer working
First i'm sure you have checked all fuses. Second you need to test if you have voltage coming out of the remote wire. If not and no fuses are blown then something shorted out internally and you need to run 12 volts to the remote wire on the amp. You can do this by using a switch and running a wire to it from your fuse box, or you can find which side of your fuse box is switchable, which means that when you turn your key to the on or accessories position that power will run to the remote then. Make sure you don't use the constant power side or your amp will remain on all the time. Now, if everything is fine and you have power on the remote wire coming from the head unit going to the amp and no fuses on the amp are blown then something is shorted inside the amp. Then I suggest you take it back where you bouhgt it if you bouhgt it at a store and your able to return it. Ifr this is not an option then I own my own amp repair business and if interested I can repair it for you cheaply. I am the cheapest you will find anywhere. Most of my customers are from this site. If interested send me a private message by clicking on my name. Hope this helps you out, let me know please so I can continue to assist you if you still need more help. Good luck
Aug 20, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Fan on amp runs constantly. will this drain my battery?
Yes, and would imply that the amp is powered up all the time.
You should correctly wire your system by
1.Connecting the constant 12vdc input wire to a constant 12vdc source to power the in-dash head units memory.
2.Connecting the switched 12vdc input wire to a switched 12vdc source to power the head units primary functions.
3.Connecting the remote output wire (typically a blue wire) from the in-dash head unit to the correct terminal on the amp, so the amp will only power up when the head unit is on.
4 Remember to run the signal (speaker) wires in a chase separated from the amps power wires, so as to avoid a buzzing noise in the speakers.
5. Always use an in-line fuse on the amp and the head units main power wires.
Note: A properly powered amp will produce a better sound quality then if it were under powered, so be sure to use the proper wire gauge as your amps power supply.
Good luck
Mar 22, 2009 | AudioBahn A2002T Car Audio Amplifier
Sony xplod xm222 amplifier in honda crv1996.
the amp will have straight power (+) with a fuse inline
the amp will also get the blue and white wire from the radio(remote power,when the radio is turned on) to the "remote power in" on the amp.
and yes ,the high output audio of radio to high input audio on the amp.
your radio wiring
Mar 15, 2009 | Sony XM-222 Car Audio Amplifier
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Amp neon lights wont turn off
There are two types of power that feed your amplifier. There is a constant power that connects directly to the battery and there's a remote power that usually connects to the remote power output of your deck. Some decks do not have the remote power output, but they have a power antenna output that works just as well.
The remote power is what enables the amplifier to turn off when the car's power turns off.
Either way, it sounds like you have the remote power input on the amp connected to your constant power source.
That would prevent the light from turning off with the car.
If you don't have a remote power or power antenna output on your deck, I would invest in a new one.
However, it is relatively easy to find a remote and a constant power source in your fuse box.
Purchase a fuse tap for a few cents and connect the remote power input on the amp to a power source in the fuse box that turns on and off with the ignition.
Some of the power sources you can find in your fuse box that go on and off with the ignition may be labeled something similar to the following:
ignition, power windows, radio, accessory, etc.
The constant power sources in your fuse box are the ones that don't power off with the car, such as the dome/interior light, power locks, battery, etc.
I hope that some of this helps out a little.
Dec 04, 2008 | Car Audio & Video
Rockford Fosgate P3001 Car Audio Amplifier Logo
101 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Level 1 Expert
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
