Question about Asrock P4I45GV R5 Motherboard
Plz help me
No beep,No Display on my monitor,only processor fan run
  • moideen09 Jul 12, 2008
  • 52 Answers
Try to reset your cmos,
you can do it by removing the cmos battery by 5 to 10 seconds then open the computer.
Posted on Jul 12, 2008
When the power does not give any beep motherboard D915GAV. Just connect your monitor to the built-in monitor video card does not work. I tried to connect the monitor is not the built-in video card as it...
If your motherboard does not give any beep and there is no display in your monitor this means there is a problem with your computer hardware. First thing you have to do is to check if the power supply fan is working, Then check thee processor fan if working too. If the processors fan did not spinning this means there is a problem with your memory or in your processor. Try to clean first the memory with a pencil eraser then put it back again to there slot. If the problem is still there then the problem is in your processor.
Sep 01, 2011 | Intel BLKD915GAVL (BLKD915GAVLX10U)...
The processor fan running no display and no sound beeping
First check display (Monitor LCD, Cables ect) and make sure that they are working.
Next check RAM and replace them if possible. Most of the times display issue with Asus is because of RAM.
let me know the out come
CreativeTECH
Nov 05, 2010 | ASUS P5PE-VM Motherboard
After turend on there are 3 beeps, no display, ram are ok tested
It is a memory problem. Verify if they are plugged in the mainboard slot.
Jul 13, 2010 | Intel DG965RY Motherboard
No display even after the system boots
You either have a dead CPU or a dead motherboard or a partially-dead power-supply -- the power-supply should supply different voltages to different computers, i.e., one voltage to spin fans, and a different voltage to power the RAM, and a different voltage to power the motherboard. So, it can be "partially" dead.
Borrow a power-supply, and try that first.
If all else fails, take the computer to a qualified technician.
May 31, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Motherboard display problem
Hear some any beeps to your motherboard. If your hear this beeps then motherboard will identify what is the loss connection of trouble of your MOBO.
If you don't then have to remove tor clear the CMOS by removing the Lithium Battery in it.
Sep 29, 2009 | HP (D7580-60003) Motherboard
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Can u help me?
check the video card of your system. if it is add on card , remove it and clean. if still error exist then maybe u need another VGA.
Jan 10, 2008 | Asrock 775VM800 Motherboard
Asrock P4I45GV R5 Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
