Question about Codemasters Video Game Consoles & Games
Blue minnions how do i get the hive out or the blue minnions lair
  • dhann40700 Jul 12, 2008
    in the game overlord pc . how do you get the hive out of the blue minnions lair
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 39 Answers
Hi dhann40700,
See this link, it helped me out many times:
http://www.cheatcc.com/pc/sg/overlord.txt
Posted on Jul 12, 2008
Chaufrette jette de lairfroid
missing antifreez or cloged heater core
Feb 06, 2015 | 2007 Chevrolet Equinox
How do i find the blue minnions
More information required please :) I would love to help you but i am not understanding your question
Dec 28, 2014 | Video Game Consoles & Games
Binatone b430 gives message "recover
I have the same problem.
My Binatone B430 shows LOGO screen or 10-15seconds and
then it gives blue screen saying "RECOVER THE HIVE PARTITION..."
I don't know what to do, any ideas guys?
Aug 18, 2011 | GPS
My laptop will not boot, instead it goes to a blue screen that states it is not able to access the hive.
I think this is the exact error : Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION:
To resolve this issue, please follow one of the following methods.
Use the Recovery Console Tool:
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console. You need your original XP CD, boot your PC from the CD and press R when it say 'Press 'R' to use recovery console.
In Recovery Console, change to the c:\Windows folder.
Type cd system32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
i understand this looks a litle daunting, please get back to me if you have any trouble with this.
Oct 16, 2010 | Sony Computers & Internet
My dell pops up with a blue screen and says "STOP: c000021a (Fatal System Error)"
To resolve this issue:
  1. Create a parallel installation of Windows NT.For additional information how to do so, click the article number below to view the article in the Microsoft Knowledge Base: 259003 How and Why to Perform a Parallel Installation of Windows NT 4.0
  2. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  3. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  4. On the Registry menu, click Load Hive.
  5. Type the path to the System hive of the prior installation, typically%systemroot%\system32\config\system, and then click Open.
  6. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  7. Note the setting for the Current DWord value in the preceding registry key. This is typically0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  8. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Managerwhere XXX is the CurrentControlSet that you identified in the preceding step.
  9. Under the Session Manager key, note and then delete any PendingFileRenameOperationsentries.
  10. Click the TEST hive, and then click Unload Hive on the Registry menu.
  11. On the Registry menu, click Load Hive.
  12. Type the path to the Software hive of the prior installation, typically%systemroot%\system32\config\Software, and then click Open.
  13. When you are prompted for the name of the key, type TEST2.
  14. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
    HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnceEx
  15. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  16. Quit Registry Editor, and then restart your original installation.
Sep 30, 2010 | Dell Latitude D600 Notebook
The registry cannot load the hive file ?
backup the current hive file, and copy the hive file from repair folder to the config folder, that would solve the problem
Aug 27, 2009 | Microsoft Windows Server Standard 2003 for...
Banjo Kazzoie
The main area of the game. This is where you’ll access all the levels by completing the jigsaws on the walls when you have enough Jiggies from previous levels. When you press a Grunty switch in the stages, the Jiggy will appear in this lair.
As you enter the lair, get the first Jiggy on the left, then go up the right hand tunnel and fill in the picture at the top to gain access to the first world.
Jul 15, 2008 | Ubi Soft Entertainment Rayman 2: The Great...
Video Game Consoles & Games Logo
219 people viewed this question
Top Codemasters Video Game Consoles & Games Experts
James Wishart
Nikki  Mclean
Nikki Mclean
Tony
Are you a Codemasters Video Game Console and Game Expert? Answer questions, earn points and help others
