Question about Xerox Office Equipment & Supplies
The printer is indicating that the finisher tray is full and to remove all paper. But there is no paper on the finisher tray.This is causing the printer not to print.
  • 2,072 Answers
I wish you told the model number. But when that happens, what has happened is this.
In the finisher tray there would be a flag type actuator that sticks out into the paper path after the paper enters the tray. It has fallen off or has become stuck deactuating the sensor, ( turning it off).
Although there is no paper in the finisher tray, with that sensor flag out of position and the sensor off,it thinks there is paper there.
Posted on Jul 12, 2008
  • Anonymous Jul 09, 2015
    I am getting the same error message on a BizHub C224e yet there is no paper in there. I didn't see any flag type actuators. Any advice on this model would be great!
Hp 2515 no paper on tray but indicating fake paper jam
May i know the printer model # / name ( full ) to assist you better. ?
Mar 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
When the paper drawer is fully-loaded and inserted properly, the "load paper" light blinks indicating that there is no paper (hence you cannot photocopy). However, when you pull the drawer out,...
if you remove the paper tray and you look in the slot that the paper tray slides in you should see a sensor flag hanging down remove the flag, it seems that the sensor is faulty the machine should work but wont let you know when the paper is finished so the very last page will show paper jam
Mar 18, 2011 | Toshiba 1370 Black and White Copier
Reading no paper paper tray is full
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Problems with bypass tray taking too many peice of paper then jamming
The tray is overfilled > Remove excess media from the tray.
The paper exceeds the maximum stack-height indicator mark in the tray (trays 2 or 3) > Open the tray and verify that the media stack is below the maximum stack-height mark.
The paper is sticking together > Remove the media, flex it, rotate it 180 degrees, or flip it over, and then reload it into the tray.
NOTE: Do not fan paper. Fanning can create static
electricity, which can cause paper to stick together.
Dec 08, 2009 | HP LaserJet CP3505n Printer
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
Cannon 3235i indicates that there is paper to be removed from the output tray but none present
i am assuming you have a finisher on the copier if its the small internal finisher were the paper lands has a small lever that moves up and down when the paper hits it if that lever is stuck down you will get this message
Jan 08, 2009 | Office Equipment & Supplies
No Paper Message- when the tray if full
When removing the tray - turn off printer -
insert try with paper - turn on printer -
you should notice the blue paper meter moving. fixed
Oct 20, 2008 | Brother MFC-8460N All-In-One Printer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
363 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
