Bios password rest on acer 220 travelmate
Hi there
I have a an acer travelmate 220 with abios password. I do not know the password so I need to rest it. Can you help please?
    Problem Solver:
  • 6 Answers
Remove keyboard and visible below battery holder is a small board with sliding pins , normally the number 2 pin out of the 8 is in the on position (off to left/on to right) slide 2 pin to off . Slide 6 pin on, reboot F2 for set up and you should be in ,simple as that, but magnifying glass needed to see pin numbers, 8 is nearest touchpad, 1 nearest screen.
Posted on Jul 14, 2009
  • riggon7 Jul 06, 2010
    wat does the rest of the 8 pins do??
  • 476 Answers
Why does he not know the password? You DO realize that the reason often is the laptop was stolen!!
If he is the legitimate owner, he can get a hold of the manufacturer and they can probably give him a universal password that works, if he can prove he is the one who registered the computer.
You could check the manufacturer's web site for info, or in manuals or service guides for how to remove a password, but there are often no instructions for how to do that in them these days. Otherwise passwords are difficult or impossible to remove from more recent laptops and notebooks - e.g. you may have to buy a new motherboard, or a used one with no passwords, or have someone replace the chip that the password is stored on, if that's even feasable. Removing the cmos and main battery from them to remove a password hasn't worked for many years. Lots of things can cause the problem you are having. Some are not fixable the the Windows CD. You can run an XP Repair installation without having to change the boot order, and without booting from the CD.
Go to the Microsoft site and download the 6 floppy Windows XP Setup set - make the floppies, boot with the first one, and by the time the sixth is loaded you can run a normal or Repair Setup
Choose the SECOND chance to Repair if you repair - install to the same directory, and you won't lose anything already on the drive. How to perform an in-place upgrade (reinstallation) of Windows XP
http://support.microsoft.com/kb/315341/
Posted on Jul 12, 2008
  • Verne Koti Jul 18, 2008
    My appologies for my first reply,
    lack of sleep and no concentration,
    I have found in the past to reset bios password is a challenge in itself,
    Ok this is how I understand this process,
    on the mother board is a battery whos sole purpose is to keep minimal power in reserve to power bios functions and memory.
    If you remove this battery the stored info will be erased after a few minutes,
    You can replace this after reset time period (approx 2 min)
    Start up and away you go.boot sequence may have to be reset
    to deault factory settings,save and reboot,
    The system should auto recognise and continue from there.
    I hope this helps,
Password reset acer
http://www.fixya.com/support/t772516-bios_password_rest_acer_220_travelmate Will give BIOS reset insts. I f the issue is a windows pacword I'd need to know which version of windows you have.
Jul 23, 2014 | Acer TravelMate 220 Series Laptop Charger...
I have a bios password on my acer travelmate 2304 and i forgot it. can you help me reset my password?
I need to know if your computer gives a code after entering the wrong code 3 times if so what is the code and I can then give you the correct Bios Password or you can see this post http://dogber1.blogspot.com/2009/05/table-of-reverse-engineered-bios.html
Mar 17, 2013 | Acer TravelMate 2304 Series Laptop Charger...
BIOS password problem
DID YOU TRY ENTER IN THE BIOS? FROM THERE YOU CAN DO A PASSWORD RESET.
Apr 11, 2012 | Acer TravelMate Notebook
Hi How do I clear BIOS password set by misstake on Acer Travelmate 2413 LCI? I can not get in to BIOS setup
When you turn on computer look for Acer logo on boot up. Press F8 or F10 or F2 while the logo comes up several times (if you miss turn it off and try again)and then you can access your bios. Use arrow keys and enter to clear the password. Follow the bottom of the screen for directions and if you need more help let me know and thanks for using FixYa.
Feb 01, 2011 | Acer TravelMate 2413LCi Notebook
How to Disable Acer Travelmate 240 BIOS Password?
To disable the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and the bios password will be disable.
Take care.
Nov 19, 2010 | Acer TravelMate 240 Notebook
I have acer travelmate 4330.i would like to know how can i insert memory card [canon] to my laptop
hi . i have on ishu . my laptop acer travelmat 4330 . i put rong password . i want .recover my bios password . how i do it now ??? thank u
Aug 09, 2010 | Acer TravelMate 4230 Notebook
Acer travelmate 2410 phoenix bios setup utility
u got to replace ur BIOS. but der r ways to recover the BIOS password using default passwords, i need to get to know ur MOTHERBOARD build.
Mar 31, 2010 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
1,656 people viewed this question
David Payne
David Payne
