Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Whirlpool Imperial Electric Dryer won't start
I have a Whirlpool Imperial electric dryer which has functioned perfectly for over 10 years.  It runs off of 220VAC and the other day it was working just fine.  We had a thunderstorm come through and lost power for about 5 hours and then it was restored.  The dryer was not in use at the time of the storm.  Yesterday, I went to dry some shirts and when I mashed the "start" button, it will not start.  FYI, the light in the drum illuminates so it is getting power.  I tried opening and closing the door in case the contacts on the safety were dirty.  Also, the timer switch will "tick" and rotate normally on its on through the cycles.  When I press the "start" button, there is no sound of the motor running or attempting to run.  Any ideas?
  • 1 more comment
  • infomail47 Aug 30, 2008
    I have the same problem with my Whirlpool Imperial Electric Dryer #LER8858EZ0. (Just happened) The start button doesn't give the slight click that it used to when pressed and the dryer doesn't start. In my case, it might be that the Relay, push to start, Part Number: AP2947429 made by WHIRLPOOL might have gone bad. Look up the model number on the inside of your dryer and you can go to to try and find the drawings and parts list for your dryer.
  • shamrocgirl Sep 13, 2008
    i have a whirlpool imperial series dryer also and it will not start when i push the start button. there is power going to the dryer as the light comes on when i open the door, and also when i turn the dial to 'stop' it clicks. the dryer worked fine yesterday.....
  • Anonymous Jan 01, 2009
    I have the same problem with the same kind of dryer. It has power, but will not start.
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Posted on Jul 12, 2008
I have a imperial whirlpool dryer. I thought it was electric, it has gas hook up and a electric plug as well , can it be bothZ?
Yes, it will be both. A straight electrical dryer is hooked up to 220 volts of electricity and uses that voltage to run both the motor and the heater. In a gas dryer, you only need 120 volts to run the motor and run the igniter for the gas, which provides the heat to dry your clothes. Hope this helps!
Feb 24, 2015 | Whirlpool Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
I press the start button on my whirlpool duet dryer and it beeps, but doesn't start
This is a common issue caused by a blown thermal fuse located on the blower housing and wired in series with the motor. Power to the motor is then cut and therefore cannot run. No dryer function works when the motor cannot run. Click on the link below for the complete details of the troubleshooting and repair procedure.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Aug 13, 2011 | Whirlpool GEW9250 Electric Dryer
My whirlpool ultimate care II electric dryer won't
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Jul 21, 2011 | Whirlpool Dryers
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
No heat whirlpool electric dryer imperial 70 1986 vintage
replace cut off switch fuse at the top of heater box
May 02, 2010 | Whirlpool GGQ8831L Gas Dryer
Whirlpool electric dryer runs only when holding start switch
if you've replaced the board replace the relay to right of bd the one with 2 blue wires to ck before replacing just switch relays the other one with red wires controls the heat
Oct 25, 2008 | Whirlpool LER4634J Electric Dryer
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
1,857 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
