Question about HP Server Tc2110
Power supply of HP server tc2110
I heard a buzzer sound followed by two beep sound when I power on the system. I search in the mannual. This beep code means that power supply is in protected mode. System not turned on but power switch remain on all time. What is the solution other than replacment of power supply. Because its too costly.
    Problem Solver:
  • 17 Answers
Hi there ,
go to the pc and shutdown then check the RAM then fix it again generally when the M/c gets older it deposits a lot of dust
Bye for now
Posted on Jan 24, 2009
How do I stop my T620 server is making high pitched beeping noise
Usually a beeping sound is due to a hardware failure, often the RAM not being read depending on the pattern of the beep. If you're comfortable with doing it, open the case and try re-seating all the power cables to the motherboard and the memory. Make sure you disconnect the power cable and flip the switch on the power supply on the back before opening the case.
I checked the manual (link below) but didn't see any mentioning of a beeping sound. It has a long list of error codes towards the end of the manual, so see if any of those are displaying.
Product Support Dell US
Jan 07, 2015 | Dell PowerEdge T620 Tower Server System...
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
It wont cut on keep making a beeping sound
beeping sound means that you have a bad power supply. Normally when booting your laptop, the power supply supplies enough power to boot to the operating system. You consult HP to replace your power supply in your laptop.
Oct 19, 2010 | HP OmniBook XE3 Notebook
I have a HPD 2537F3R. When I try to start the computer the green light on the psu goes out and nothing happens
draw the power supply from cabinate then short green and black wire at o/p of power supply then give the power if fan is rotating then power supply is ok if not then faulty. fault may lies between cpu draw the ram and listen the beep contineus beep should be heard then ram is faulty if no contineus beep then motherboard is faulty
Mar 04, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
HP ML150 g5 dont star
1. try replacing thermal sensor
2. try replacing power supply
3. then systemboard last
Sep 24, 2009 | HP Compaq ProLiant ML110 G4 Server
Disk I/O Error: Status = 00008001
Some simple things it could be...Check the screws on the mainboard holding it to the case. The mainboard uses these screws to ground the board and sometimes they can loosen up from heat & cold expansion over time. Also dust is conductive and if enough gathers on the board it can cause problems also. So use some compressed air on the mainboard to clear out the dust. And also a power supply going bad can cause problems like this. If you have another computer with a working power supply try swapping it out and see if that works. More info on the setup would be helpful.
Sep 05, 2009 | HP Server Tc2110
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
Warning beep no boot
Re-seat the video card and memory first,
if it continues to beep count the beeps 3 long ,3 short .etc
they mean a code.
if you have 2 sticks of memory try using one.
Feb 14, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
The PC doesn't work
I know this is about a year later but I just had the same problem too last night.
When you turn on the PC it plays this crazy tone music right? If so, listen to it then at the end you will hear a couple of beeps. In my case my system beep twice at the end. 2 beeps for me indicated Power supply was in protected mode. Luckly I had a spare P4 PS laying around which solved the problem.
If you have different beep code google up "HP Vectra VL420 Beep Code". Standard beep code doesn't apply to this mobo since the BIOS is customized.
My power supply was a standard P4 ATX... no special design from HP you should be able to get one at any computer store. Beware just don't the cheapest one it cuz they aren't build to last and aren't reliable. Trust me I've seen too many people buying cheap power supplies and having them kill their mobo's.
Apr 23, 2007 | HP P5750-69001 - System Board/P4...
HP Server Tc2110 Logo
291 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
