Back to:
Tags:
Sanyo DP32746 32 in. LCD Television
Vertical
posted by eugnu on Jul 12, 2008
I have a very bad vertical line going fro the top to the bottom of the screen on my 32" Sanyo Vizon lcd tv. This is the second time in a year this has happened and I had to get Sanyo to replace the first on.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Flat Panel Televisions problems?
Turning on flicker then no picture. Had sound. Pushed...
I have a 32 inch Sanyo model #DP32746 that wont power up....
i need a replacement screen for a Sanyo DP32746. are there...
Picture went black, sound is good. Assume from my research...
for remote
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
