Question about GE JBP65 Electric Kitchen Range
Electric range not heating
GE electric self cleaning oven. All the lights come on but no heat.
  • 93 Answers
Remove back cover of control and check bake leads. Or turn power off. Remove element (bake) pull forward slowly to expose the connections to element, remove from element, make sure they do not retract back into cavity. Make sure they do not touch anything and turn on power set control to bake then check voltage on leads. 240 volt is what you need. If no voltage then replace control. If voltage is present replace element.
Posted on Aug 01, 2008
The preheat light flashes on my he range and oven does not heat. I have had the sensor checked and its working. What else could it be?
Most likely the heating element is bad. Disconnect the oven from power. You can open the bottom of your oven to expose the heating element and see if there are any signs of burns or melting. If you can, remove the heating element and use a volt/ohm meter to check "continuity" across the element ... it should be a dead short. While performing this inspection, confirm that the wires and connectors leading to the heating element are intact and connected.
Oct 28, 2014 | GE 30" Self-Cleaning Freestanding Electric...
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
The broiler and self cleaning oven does not work. Everything else is ok.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 07, 2011 | GE JBP71 Electric Kitchen Range
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. How do I clean the area that has browned?
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Jan 28, 2010 | GE 30" Self-Cleaning Freestanding Electric...
I have an older GE self-cleaning oven. It has an
Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
GE JBP65 Electric Kitchen Range Logo
259 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
