Question about Frigidaire PLEF398AC Electric Kitchen Range
Burners will not turn on and it beeps code f5
I replaced both boards and the range does not work and all burners say f5 and it beeps what else can it be? Found a mouse electrocuted at the front left burner before I changed the main board. model is plef398ccc.
  • earle310 Jul 13, 2008
    rechecked all wiring and all is o.k.. Long story short, front right burner stayed on and I replaced relay board. All burners did not work and it beeped and flashed f5. research shows to replace clock board. Did that and same outcome. I hope that it is not all burner controls are bad. What do you think?
  • 2,071 Answers
For a detailed Range/Stove/Oven illustration, click below.
burners will not turn on and it beeps code f5 - redarrow.gif Gas Free Standing
Gas Cooktop
redarrow.burners will not turn on and it beeps code f5 - redarrow.gifh_mi Electric Cooktop
redarrow.gif Gas Walloven
redarrow.gif Electric Walloven
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It's stopped completely
It won't bake
It bakes poorly
It won't broil
A burner doesn't work
A burner works only intermittently
I can't adjust the burner temperature
It won't bake or broil
The clock stopped
The temperature is wrong
The oven light doesn't work
There's a self-cleaning problem
The oven door won't close
An indicator light doesn't work correctly
The oven is hot on the outside
I see sparks!
The drip pans need replacing
Posted on Jul 13, 2008
  • 13,433 Answers
Check the door.
Frigidaire contact info.
USA 1-800-599-7569 or Canada 1-800-213-9398.
Posted on Jul 12, 2008
  • 1 more comment
  • Ekse Jul 12, 2008
    check the door, the door sensor? All I got was Check the door.
  • Ekse Jul 12, 2008
  • Ekse Jul 13, 2008
    F5, 6, 7 - EOC (Electronic Oven Control) failure - Replace component
  • 481 Answers
The fault codes can be found here: http://www.repairclinic.com/0078.asp#Frigidaire
  • the codes depend on what version of stove you have, that is why i used a link to them.
  • double check your wiring and make sure nothing is shorted out or wired incorrectly.
  • all the burners share the same neutral wire so that is where i would look first.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
    Mike
  • Mike Durland
    Mike Durland Jul 13, 2008
    my assistance has already been rejected, so i don't know if you will get this post. before buying any more parts, check to make sure you are getting a full 220v at the outlet and test each leg (110v) against the neutral and ground wires to make sure they are good too.
  • Mike Durland
    when you get a short, like the dead mouse scenario, the breaker might trip on one side of the dual breaker, giving you a machine that seems to have power but does not function properly.
Frigidaire f5
Hell Gina, thank you for your inquiry!
I understand you have already tried resetting the range. It is important to wait roughly ten minutes and then turn the unit on. Since the error code F5 reappeared, it typically indicates a communication error between the power board and UIB (user interface board). In this case, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is order and installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Sep 06, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool gas range f5 code
F5 is a fulty display control board. Unfortunately there is nothing you can do to fix this problem but to order and replace the display control board.
Here is the board to order.
Dec 02, 2012 | Whirlpool GS563LXSS - stainless Steel Gas...
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
F5 display not turning burners on
Hi
Thanks for using FixYa. Error F5 means that the control board has failed and to resolve this unfortunately you’ll have to replace the control board. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
KitchenAid KEDT105V Electric Stove - f-5 beep Started beeping out of the blue, pushed cancel and it stops for 20 seconds then continuous beeping. If the oven is on the beeping will stop. Hope you can help,...
Hi, F5 means your control board may have suffered a fatal error. Unplug the unit for 30 seconds, when the power is re-applied if the error comes back you will need to replace the control board (ERC). Mike
F5 Board failure Replace control board (also called ERC or clock).
Mar 25, 2010 | KitchenAid KESC307 Electric Kitchen Range
Circuit board has been changed and now I get an error message F5
GO TO http://www.repairclinic.com/0078.asp THEY HAVE ALL THE FAULT CODES. I WAS ABLE TO FIX MY JENN AIR WITH THIS LIST. THE PART WAS AROUND 20.00 REPLACED IN ABOUT 20 MIN
Jul 28, 2009 | Jenn-Air SVE47100 Slide-In Electric...
F5 error
HI. I have researched this fault code and this is what we came up with.
Mar 21, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Error flashing F5
We had a similar problem where F5 was flashing but the burners actually continued to work. It turns out that this was related to moisture (the problem typically happened when boiling water). Adding a strip of aluminum tape inside the back panel seems to have solved the problem (fingers crossed).
Oct 11, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire PLEF398AC Electric Kitchen Range Logo
405 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
