Question about Frigidaire FGB24S5A Gas Single Oven
Oven temperature Hi, My gasn oven cannot provide temperature higher than 200 degC. when we tried to use Pre-heating, Bake Temp directly and Self-Cleaning controls. Lighting up is no problem as I can see the flames came on initially. Could it be the temperature sensor needs to be replaced? If so, how to access it? Thanks Patrick
    Scholar:
  • 170 Answers
Here's a link for you: http://www.partselect.com. This site, you give your make and model and it will show you exploded diagrams of your appliance and how things fit together. Good luck!
Posted on Jul 20, 2008
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Oven won't heat
quite possibly the element burnt out .
Sep 22, 2017 | Dacor MCS230SS Millennia Electric Double...
I dont know how to use the oven properly. when i need to bake or roast something i want to put in my own temperature, but there is no option for me to do that. when i turn on the stove all i have is the...
There should be a plus/minus sign OR a up/down arrow to adjust the temp.on the control/touch panel. The default setting is usually 350 and can adjusted up or down accordingly,the display starts at 120 and is supposed to rise as temp. increases.
The bigger issue though is to have it serviced and see why it doesnt rise above 200
Gene
Aug 04, 2011 | KitchenAid KEHU309 Stainless Steel Dual...
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Frigidaire FGB24S5A Gas Single Oven Logo
74 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
