Question about Whirlpool Duet GHW9150P Front Load Washer
Error code f-20
Duet sport washer goes for a few minutes then stops and flashes F-20. usually does this on a normal/casual load. then washer locks up when we try to fix it and buttons don't work for awhile.
  • brooksie1806 Aug 16, 2008
    My Whirlpool Duet front load displays the same error F20. It goes through the spin cycle and on any size load lately it has been giving me the F20 error and stops spinning. I have to pause the machine, hit the drain/spin to get it to finish spinning. Then have to rinse and spin. Very irritating and time consuming since the machine is on the lower level of the house. I have had the whirlpool since Oct. 2007 and until a few weeks ago it has been fine. Any suggestions? brooksie1806
  • 246 Answers
F20 is a "No water or insufficent water supply" error code. First make sure both of your valves from the house are turned all of the way on. Next make sure your fill hoses (the two macthing ones that go to the back of the washer) are not kinked. If both of these check ok, turn off your water supply and unscrew the hoses where they connect to the machine. There are 2 screens underneath that trap dirt and sediment so they don't get to your valves and cause them to run. If it's coated, rub the surface with a tooth brush or small flat head screw driver. Rinse with a little bit of water and repeat. If the screens are clear, check the hoses. Some hoses have the same kind of screens that can be on either end of the hose. If all of these fail, you'll probably need to replace your water valve. Remove the 3 #20 torx screws on the back side of the top panel. Push the lid slightly towards the rear and lift up and out of the way. Next, unplug the connectors going to your valve (should look like light blue plastic and the hoses were hooked to it). There will be a 1/4" screw on the back panel holding your valve in place. Once removed, you can slide the valve to the side and slide it out. The only part left is squeezing the clamp on the black rubber hose inside the unit to let the valve fully disconnect. While the water in this hose generally wont hurt anything, it also can't hurt to have a towel to catch the small amount of water in it. Replace the valve with one you've ordered online from the manufacture or purchased from your local appliance parts store. Re-assemble.
Posted on Jul 12, 2008
My two year old washer was consisitently stopping mid cycle and flashing this and other error codes. More intense scrutiny led me to believe it wasn't draining properly. I can't believe how simple this was to fix but not mentioned at all in the manual. Un plug the machine.Take off the front bottom panel by removing the three metal screw at the bottom of the panel, the front should then just pull out. Behind this you will find a trap that is designed to catch stuff before it enters the pump. Being prepared for a good deal of water, unscrew this and clean out the trap. Clean the threads and screw it back in. Then put the front back on. Voila. Your good to go for a few more years and you will be able to afford to go out to dinner with all the loose change you find in the trap. Why do they not mention this in the manual? Hoping for those lucrative service calls?
Posted on Oct 07, 2009
Washer stops during cycle with an error F20
Hi
Please check this link to get error F 20 resolved:-
http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Motor error with out error code.
use tech sheet to follow test routine. C:05 is Heater test. some steps take time. during normal operation if timer display flashes, may be indication of standby/pause. Door lock sw may be bad(intermittant)
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER RUNS FOR 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F
can u switch of hte michine at the wall and leave it for 20 mins and turn it on again
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer won't spin
dduet front load fills--no wash drains what's wrong a belt?
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer stopping mid-cycle with no error
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
How abt a nice rating for the free help?
Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-H code
The following link explains the "FH" error code in detail:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
There's also some helpful advice another user provided at the end of the link (bottom of the page) that may also help you. Let me know if you require additional assistance. I hope this helps you.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,253 people viewed this question
Dan Webster
Dan Webster
Sal De
