Question about Hotpoint RB757 Electric Kitchen Range
Self Clean cycle
The Self clean cycle no longer generates high heat sufficient to clean the oven.Should I be looking for a new Range or is there anything that I can check first with views to repair?
Is this range electric? if so then does it bake or broil ok? if the answer to both the questions is yes!.. I don't think you need a new range, Cleaning cycle is based on both elements working along with other componets , if you are an handy man there is a mini manual on the range somewhere it could be inside the back panel, that will give you some info, if you are able to read the wiring diagrams ect, or could be your digital control, if you donot feel good about this and most don't I would call a good service Tech...
Guest 2
Posted on Jul 26, 2008
How to use the self clean feature for a Frigidaire FES 355 ASF
Hi Anonymous, this is AP!
I understand you are interested in the self-clean process for your Frigidaire slide in range, model FES355ASF. Start by removing all excess spillovers in the oven cavity before starting the self-cleaning cycle. To clean, use hot soapy water and a cloth. Large spillovers can cause heavy smoke or fire when subjected to high temperatures. Clean any soil from the oven frame and the door liner, but avoid cleaning the oven door gasket. These areas heat sufficiently during self-cleaning cycle to burn soil on. Clean with soap and water. Remove the oven racks, broiler pan and insert, all utensils and any foil. These items do not withstand high cleaning temperatures
Make sure the clock shows the correct time of day. Push the CLEAN button "---"will appear on display. Push the up arrow button until "3:00" appears for a 3 hour clean cycle or push the down arrow until "2:00" is displayed for a 2 hour clean cycle. Once the time is selected and released CLn will appear on the display. The door will then automatically lock and the LOCK indicator light will flash. Do not open the door while the indicator is flashing, usually about 15 seconds. The LOCK display will stay until the cleaning cycle is complete or cancelled, and the oven temperature has cooled to a safe temperature.
In the event you need to stop the cycle at any point, simply push the CLEAR OFF button and the door will automatically lock once the oven has cooled, usually about an hour.
Best of luck,
Apr 03, 2014 | Frigidaire FES355 Electric Kitchen Range
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
Whirlpool RS385PXBQ0 slide in range/oven won't work after self-cleaning cycle.
Check the wiring on the door lock. If that looks good you need to replace the door lock but that part is no longer available.
Oct 22, 2013 | Kitchen Ranges
Can I use the stovetop when my oven is self cleaning?
Yes you should be able to but there are a couple things to consider. When the oven is in the self-cleaning cycle the heating element reaches a very high tempature and runs for extended periods. So if you have a couple top burners going the amperage draw could possibly trip the electrical breaker. Also there is a lot of heat generated around the range during the cleaning cycle and it may be to hot to actually work around the range. There are some ranges that dis-able the top burners during the self-clean cycle. If that is the case with your range then the answer would be no. The way you would know for sure is to try them during the self-cleaning cycle or consult your owners manual.
Apr 10, 2010 | Maytag MER5770 Electric Kitchen Range
Oven door is locked and will not clear. I have tried to reset. Turned the breaker off, The only button that works is the timer. I am not cleaning the oven it was locked by accidentially leaning against the...
Hello JJ, Try pressing the "Clear/OFF" button to stop the self cleaning cycle. It will take up to an hour before the oven will unlock the door, if the oven has started to heat up for the cleaning process
You may have started the default 3 hour self-clean cycle, so you can attempt to reduce the time to 2 hours, by pushing the timer down so it displays "2" which would indicate the shorter cleaning cycle. Then at the end of the timed cleaning cycle, it should open up, once the temperature has cooled sufficiently for it to be safe to open, again, which takes up to an hour to sufficiently cool.
Typically, when an oven is accidently put into self clean mode, the timer "kicks in" and the timer has to run out before the oven will unlock. With the older mechanical knob timers, you could just rotater the timer until you reached the end of the pre-set time. With the electronic timers, you have to let the timer "count down" until it reaches zero before the oven will unlock the oven door.
Here's a link to the Frigidare site where you can select your specific FEF352 version and download a owners manual, free of charge.
http://www.frigidaire.com/manuals
Just enter in FEF352 and then scroll down the page until you find your particular version of teh FEF352 oven/range and then click on "complete owners guide" (english) to get the manual in an Adobe pdf format.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Frigidaire FEF352 Electric Kitchen Range
Self Clean cycle on Hotpoint Gas range doesn't work
We see a symptom like this due to a failure in the control board. Although it usually also affects bake mode. Another cause could be a problem with the door lock as it must be engaged (by the controller) to initiate self-clean.
If this doesn't help, you can either post the full model number or email me at bruce@fixyourboard.com and we can dig deeper.
Oct 09, 2009 | Ovens
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Oven cleaning bosch oven
self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
Feb 10, 2008 | Ovens
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
Hotpoint RB757 Electric Kitchen Range Logo
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
