Question about Frigidaire Dishwashers
New dishwasher: Top Rack - two fold down shelves WHAT IS PURPOSE? Need pictures/instructions on proper loading as designed by manufacture engineers!
  • wlsh69 Jul 12, 2008
    Need instruction/pictures on proper loading of dishwasher. This should be included with the machine. Picture should show dishwasher loaded to full capacity.
    Already has a basket for long pieces of cutlery.
    No way to hold anything on the shelves?
    Please! This is not a major problem just a need for some simple instructions with display pictures.
    Thanks
    President:
  • 1,462 Answers
Use them for whatever you want. i find they are usefull for long pieces of cutlery - carving knives etc
Posted on Jul 12, 2008
Top rack slides all the way out
Most likely your dishwasher is not level, but is tilting forward. Just extend the front leveling legs down further to raise the front end of the dishwasher. Otherwise, the rack glides may be damaged or bent.
Sep 18, 2014 | Dishwashers
Should I get a wine wall rack or the traditional shelves rack?
I strongly recommend the shelves rack and thisis for the following reasons: First, the wall rack is more likely to fall fromthe wall where the shelves seem more firmly designed. Second, the wall rack Ihave seen have the bottles stuck in it in a way that they look like they areabout to fall - I personally does not like this type of design. I like my wineto be firmly held in the traditional way, but, hey, this is me.
May 29, 2012 | Furniture
Loading dishwasher bad design
Unfortunately all dishwasher manufacturers build the inside of their machines differently so you can't really swap the baskets between makes and models.
Some manufacturers actually put a lot of thought into their rack design but you usually have to pay a bit more for them.
Mar 07, 2012 | Dishwashers
I have to replace the handle / latch assembly on a GE Monogram Dishwasher Model #ZBD6600G03SS. For the love of me I can't see how to do it. Do I have to get at it from inside, outside, both sides...
Hi
If the dishwasher door will not latch on your GE Monogram dishwasher and it is a new appliance, check that the door is not hitting screws or cabinets underneath the counter. For a new dishwasher, you might also need to push in the top of the control panel as you latch the door. The new gaskets might not have had time to seat properly. It may be necessary to run up to 10 dishwasher cycles for the heat from the washer to seat the gasket, which becomes more flexible after it is used a few times. For older Monogram dishwashers, check the loading rack to be sure no dishes are protruding beyond the back or front of the racks and that no dishes have fallen through to the lower rack. If dishes are dangling down into the lower rack, they could stop the lower rack from completely rolling into the dishwasher and could also stop the spray arm from rotating. Check that no silverware is obstructing the door.
http://www.acmehowto.com/howto/appliance/dishwasher/check/doorlatch.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Aug 03, 2010 | Dishwashers
Design Flaw
a design fault reported and worked on under warranty remains under warranty until it is fixed properly
discuss the problem with legal representative to get the facts
it probably comes under the not fit for the purpose clause of consumer law
Mar 27, 2017 | GE 24 in. GSD2120C Built-in Dishwasher
Just installed new dishwasher top rack will not slide in
I had the same problem with my new GE. They installed 2 brand new upper racks.$$ it worked ok for about a month and then I had to force it in again. on the 7th repair call in as many months my repair guy walked in the door stating that he finally knew how to fix the problem. It is caused by poor design in the wheels. they are porous and the detergent breaks them down and they swell. new wheels from an older model fixed the problem. they have RND on the case.
May 30, 2009 | Frigidaire PLD4375RFC Dishwasher
My scanner will not scan negatives
Most scanners aren't designed to scan negatives. (Of course the manufactures would never want to tell you their product CANT do something).
Flatbed scanners typically have a light on one side.
To scan negatives properly, you need to have a scanner that has a backlight, or a second light in the bed's lid that you fold down.
Canon USA, Inc. make a few flatbed scanners that have backlights. They range from $60 to $180, depending on the features and resolution you want to pay for.
Please see the below link. This is a more expensive one, but is shown just so you get the idea. In the pictures, note specifically in the picture that shows the lid open, how the white backing on the lid can be removed from a clip at the top. Underneath, is the backlight and clips designed to hold negatives in with the included frames.
http://www.newegg.com/Product/Product.aspx?Item=N82E16838111015
May 04, 2009 | Epson Perfection V200 Flatbed Scanner
I have a Kenmore Ultra Wash Dishwasher and the 3rd level spinner broke off. I have a new one and now need to know how to replace it.
the manifold in the back of the dishwasher needs to come out. you can either pop it all the way out it only undo it halfway if your arm is small enough.. there are either 2 tension clips or 2 screws holding it to the top and back. if you undo the top of the manifold and pull it down you should be able to slide the new part in place. the plastic push pin goes on top of the manifold and the spinner goes on the other side. it may be a little difficlt to push the 2 together..
Mar 06, 2009 | Dishwashers
Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Feb 02, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Snowbard rack safety
not specific for snowboard buy general rack use : 1. The Lighter the Better Most minivan roof racks are designed for carrying lightweight objects -- like skis, small ladders, well-secured aerodynamic cargo containers (like those offered by Thule) and other light loads. 2. Mind the Center of Gravity Putting heavy boxes, bulky luggage and other weighty objects on your roof will raise the center of gravity of your vehicle, which could increase the chances of a rollover during emergency maneuvering or in the event of an accident. The National Highway Traffic Safety Administration (NHSTA) also encourages drivers to follow auto manufacturer guidelines for roof rack usage. * Rollover Risk: Load Vehicles Properly [NHTSA] 3. Strap and Secure Improperly secured roof cargo can also fly off and strike vehicles travelling behind you, sometimes with tragic results. Remember: Only put lightweight objects on your roof rack, secure cargo properly with tie-downs and strong cord, and consider purchasing an aerodynamic cargo container if you plan on using your roof rack to frequently carry light loads. More Minivans Quick Tips Sponsored Links
Dec 01, 2008 | Academy Snowboard United States Naval...
Dishwashers Logo
46 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
