I have a Whirlpool AKZ446ix fan assisted oven which was fitted before we moved in to our home. The oven seems to work fine but the grill smokes and smells the house out. Is there anyway to remedy this?
On this setting the fan and element get power at the same time. If the fan is working it is fairly safe to say that the element is blown or there is a problem with the wiring at the terminals of the element. You can visually check the element terminals and wiring and if okay the element will need replacing.
If it is a fan assisted oven and the fan is working o/k, then you need to replace the oven elemnt, located at the rear of the oven compartment behind a removeable cover.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
[f it is an electric FAN assisted oven, and the fan is working o/k, then you to replace the oven element.
It is usually located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
If it is a fan assisted oven and the fan is still wiorking o/k, then you need to replace the oven element, located behind the rear panel in oven.
Thanks.
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
