Question about Kenwood KNA-G510 GPS Receiver
KVT-719 NAV button not highlighted unable to select
Can use NAV by peressing "V" but the NAV button on main menu will not work, why not?
Well I see no help here, but emailed kenwwod and they told me:
The Garmin menu is not accessible from the main source select screen, only thru the V.Select which you have already discovered.
The reason why "NAV" is displayed as an audio source is if you were to add a GMX30 XM Radio/NavTraffic antenna, you would be able to access XM radio (subscription required). So unless you have the GXM30, you will never use that source key.
Posted on Jul 22, 2008
Stop a nav route
Once you pick your new destination, the unit will ask if you want to delete the previous destination. If you just want to delete the route, hit the menu button, go to destination, and it's the bottom right selection.
Mar 25, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Tip
How to change language on TomTom GPS Sat Nav
If the language display on your TomTom has changed and is now unrecognisable, it can be very frustrating to find how to change it back as the menus are no longer clear to understand.
This Tip is written with illustrations so that you can easily Navigate to the language menu and reset the display.
1) First tap on the centre of the screen to bring up the main menu as shown below..
2) Next tap on the preferences Menu (Spanner/Wrench Icon circled below)
3) With the preferences menu open - the icon you need to tap is this one.
4) This menu displays all available languages. Scroll through each one until you find the required setting. You may have to work through each one of these language options if the meaning remains unclear.
Once selected, the language used for all the buttons and messages on the unit will be changed. Once you have selected your language, you will also be given the opportunity to change the voice if required.
Hope this Tip helps. Please do please remember to leave a vote for this solution.
on Feb 05, 2010 | GPS
Nav-cam 7700 returning to main menu after planning route
Evesham is no longer in business but the following url is for a company that supports their products. They have ex-Evesham employees on staff..
http://www.tewktech.com/
Good Luck and please rate this solution
Feb 08, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Unable to set the time correctly
Try to set it again:
1/Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2/Move the field highlight to the OFFSET field
and press Enter
3/With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4/Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
5. Press QUIT , to return to the MENU Page, then select
Navigation Setup “NAV SETUP” with the Up & Down arrows (↑↓)
then press ENTER
Hope that helps.......
Jul 02, 2008 | GPS
Nav Cam 6400
I've wiped the card and copied the back files off the cd back onto it and put the update back on.
Seems to be working fine now but you will loose all your settings and favourates.
Jun 24, 2008 | Evesham Nav-Cam 7700 GPS Receiver
i have the same problem, turn the speed cameras off im afraid
May 15, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Installing kna-g510
You have to select your video source to GPS instead of the source in the main menu to GPS
Jan 22, 2008 | Kenwood KNA-G510 GPS Receiver
Goodmans sat nav gnav12
get your money back
Nov 28, 2007 | GPS
Not working
From the Main Menu press the button underneath the spanner>Demo and deselect the first square if it is ticked>Save.
With your device turned off, press and hold the "OK" button in between the arrows and press the "On" button.
On screen you should see the "Maintenance Menu". Scroll to "GPS menu" using the arrow keys and select it using the "OK" button. Select "Perform a GPS cold start". When this has finished, press the "Home" key twice (the one with the three lines on it). Turn the unit off, then go outside, raise the antenna, and turn it on again. Keep it still for 10-15 minutes and the unit will start to pick up GPS again.
Oct 30, 2007 | Navman iCN 320 GPS Receiver
Kenwood KNA-G510 GPS Receiver Logo
212 people viewed this question
Top Kenwood GPS Experts
Mike
Are you a Kenwood GPS Expert? Answer questions, earn points and help others
