Question about JVC AV-35750 35" TV
Power supply problem
When I try to power up the tv it cycles on for a second the it goes off. What parts in the power supply should I try to replace?
I had the same problem. The power light would flash once but never got a picture. Was also previously having sound problems for a few seconds on startup. Changed capacitor C926 (1000uF 16V) for 1000uF 63V and it solved both problems.
Posted on Dec 07, 2008
My tv did the same thing. Replace the capacitor marked C926 that is marked on the main(big) board. It fixed mine. The lead was broke off inside the capacitor.
Posted on Oct 04, 2008
Help diagnosing a problem with a LG 50PA6500ua T.V. will not turn on.
sorry tv number does not match any on search. plasma tvs can be a pain to diagnose, but usually if its in cycle mode, it will be a regulator chip on the voltage side. and the voltage regulator on main controller for the Y board cycle mode is its trying to turn on the back light and the voltage is either to high or too low. can also be voltage is in ac when it needs to be dc. as there is a mix on board parts this can be the bridge rectifier. left side board there are a few parts on this board that can need replacing if it has gone wrong. there are repair kits for this board you will just need to find them. an LG i repair, the parts had to come from china as they were not available anywhere else. but these fixed the power problem.
Feb 16, 2018 | LG Televison & Video
Vizio tv repair picture blurs and darkens for five seconds and then goes normal for five seconds and continues this cycle. i changed the tcon board and no change.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 29, 2015 | Vizio Razor M501D-A2R 50" LED Smart TV...
The power light will come on for about 18 seconds then goes off and then comes back on and goes off etc.
It sounds like your power supply is cycling. Check power supply output and replace. I've been told by a TV repairman that the power supply (and motherboard) in smaller sets is the same as yours.
Oct 29, 2013 | Sanyo 42 in. LCD TV
Hi my samsung crt tv come up on start up but couldn't stay for more than few seconds before it goes standby. I've tried to check settings but could not even get anywhere before it goes back to standby
Whenever a television starts doing this the motherboard/main board and or power supply is usually at fault. The power supply can usually be rebuilt for around $150 depending upon the knowledge and skill of your local television repair shop. To replace the parts is usally more expensive then it would be to purchase another television ($300 and up). Are you sure this is the model number of your television because this model number is not for a CRT television. For troubleshooting you can unplug it overnight to try and power cycle it but it sounds like your problem is beyond doing any type of power cycle to get the television back going again. It would need the repair shop or to be discarded for another.
Oct 29, 2011 | Samsung LNT3242H Television
27gt271 goes on for 1 and a half minutes then shuts off. After a time the cycle repeats itself. Then the fuse blew and nothing.
Theres a problem in power supply.Maybe theres a leak capacitor or transistor.Please check the parts in the power supply and try to replace leaked parts.
Jul 16, 2011 | GE 27GT270 TV
I have a 32" Protron
The tv power supply board,that the board where the tv power a/c cord plug into it.U know basic electronic,have all the tools also can do soldering work too?Tries check the tv power supply board for dead components parts call capacitors parts,most of the times the capacitors parts are bulges ups or puffing ups onto it tops.These capacitors parts are dying or already dead.These capacitors parts are dead must to be replace.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 22, 2011 | Protron PLTV-32 Television
My tv will not turn on unless I do the same routine each night. First, I have to remove and insert the power cord from the back of the tv several times until the power button begins to flash without...
The tv power supply board have problems and the cause.That the board,where the power a/c cord plug in to it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 14, 2011 | Televison & Video
The on/off led light goes blue for a second, then
Power supply board it dead.That the board,where the a/c power cord plug into it.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 07, 2010 | Insignia IS-LCDTV32 32 in. Television
Troubleshooting akai 32
won't turn on, green light comes on and them click sound and goes red, never a picture. continues to cycle through this every ten seconds or so
Aug 25, 2008 | Televison & Video
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
Televison & Video Logo
275 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
