Question about OKI C5500n Printer
False empty toner reading
I am getting a false toner empty reading--toner has been replaced. Any suggestions on how to fix? False paper jams, false empty toner, flashing orange light, records print commands, but no longer prints.  Display screen gone blank.
    Brigadier General:
  • 6,966 Answers
You may need to do a full reset.
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
The above is of course assuming no hardware/firmware fault on the printer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 12, 2008
  • Louie  Role
    Louie Role Jul 12, 2008
    Hi again,
    The above is an excerpt from this site. You might find it informative if not an interesting read.
  • OKI Master
  • 2,794 Answers
It sounds like the whole printer has gone nuts.
Turn the printer off and unplug the printer. Wait 30 seconds and plug it back in and turn the power switch back on.
It resetting the power doesn't work, it soulds like it needs a trip to the repair shop or another one.
  • 2,427 Answers
The problem can be may this however hard resetting it can fix the issue
8. Restart printer.
  • Rishi Roshan Ali Jul 12, 2008
    That should work and solve the issues
    The problem comes because of the microprocessor and the hardware programming, sometimes it freezes and has data bits stuck in it, normally this should be corrected by turninf it off and on dumping the memmory but sometimes the settings gets messed up. for example the printer contains a built in timer or clock to measure toner amounts, transfer drum life etc. if this gets stuck then the problem insues, you can alos use the aove reset if you wish to refil your toner as well..
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Frequent paper jamming, occasional false paper jam indication, black shade on the right side of the paper in my 10 months old (counter-64000 prints) Kyocera fs-1024 MFP photocopier. Cleaned the glass,...
Myself able to solve the issue, by replacing the drum yesterday. The drum is damaged due to non-removal of waste toner! Misguidance, improper service from Abhishek Enterprises, Shimoga.
Sep 22, 2013 | Office Equipment & Supplies
How to fix a false jammed paper on an hp officejet 7500 printer
How do you know it's false? a small piece of paper can still sit in one of jam sensors causing that.
Feb 27, 2012 | HP Officejet Pro L7590 All-in-One InkJet...
My printer gives an error message "paper jam" when there isn't any jam
Paper is nearly always sensed with little, black levers that are pushed out of the way as the paper passes over it. Inkjet printers normally have just one sensor, while laser printers often have three to localize a jam in the paper path. Take out the paper and drum/toner assemblies and look carefully for the levers. See if they wiggle freely. Since they must be delicate enough to be pushed aside by a sheet of paper, it doesn't take much dust to stick one down, giving a false jam reading. A little wiggling and blowing might fix it.
Aug 18, 2011 | Brother Office Equipment & Supplies
Hp 309n false paper jam
just fixed mine! So easy, just cut a piece of poster sheet down to paper size and pushed it through the printer. Works fine now. (I had the false paper jam error message, The printer doesn`t know the difference between a stiff roller and a paper jam!)
Dec 06, 2010 | Office Equipment & Supplies
How can I fix a paper jam on HP OfficeJet 4580
hi,
Paper jam messages can be true or false. The product might report a paper jam when there is not any paper jam. The following steps resolve both true and false paper jam messages.
this link will help you out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368841&cc=us&lc=en&dlc=en&product=3645100
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
OKI C5500n Printer Logo
612 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
