Question about Nintendo DS Lite Console
Power connecter plug stuck
The connecter plug from a car charger is firmly stuck in the ds and cannot be removed. it was put in the correct way and went in without problem. the same plug works fine with 2 other ds's and has been used before without problems. please help!
  • 1 more comment
  • slimey Jul 18, 2008
    fixorfixnot - thanks mate, it actually came out eventually, but that was useful to know
  • jopparai Jul 19, 2008
    I cannot get the power connector out! It's the included power supply that I'm having trouble with. I tried removing the battery, but I can't see those prongs or whatever it is that holds it in place. I'm afraid I'll break it if I use all my might... This is the DS Lite we're talking about.
  • Anonymous Oct 07, 2008
    I also cannot get teh pwer plug out of my nintendo DS.  This is apparently a big problem with them.
Hey!
I took it down to the store, and they just tore it out. It just took a lot of strength on the first try. It's much easier now. Thanks anyway!
Posted on Aug 23, 2008
  • 61 Answers
Remove the battery, looking at the jack on the left side is a prong that holds the charger in place also to make contact with the charger, try taking a pin and push the prong against the left wall. there is also one on the back right side
Posted on Jul 18, 2008
  • ED STOKES Aug 22, 2008
    follow up
    jopparai--the prongs are not next to the battery, the battery is to be removed to stop current. look inside the charging port
Please Help! my nintendo ds lite wont charge?? i replace the battery from another ds and my ds turns on. i take of the battery an plug the charger directly an i get no power?
remove and re plug the new battery,connect the power cord, let it for few minute and then power on.
vote me if found helpful.
Aug 05, 2011 | Nintendo DS Lite Console
My DS won't charge. I plug it in the red light stays on for about rwo seconds then nothing. So what could be wrong????
i have got that dont worry look the battery could be loose !! i know what your saying " LOOSE ???" well yeahh just put paper or anything until its FIRM and tight THAN you can put the charger OR if that dont work than find a new charger on EBAY..
Sep 01, 2010 | Nintendo DS Lite Console
Charge a DS lite without DS charger
turn your ds lite on, then realy quickly close the lid
Jul 20, 2009 | Nintendo DS Lite Console
DS is stuck in charge mode when plugged in.
Your DS may have a problem reading the battery gauge, and the DS will only let the charger do its thing for a period of time. Then, if it is still connected, it may burst more charge in. This means that your DS is acting up, and your battery may have a rare (and not harmful to the DS) malfunction.
Jun 10, 2009 | Nintendo DS Console
Car chargers stuck in nintendos, 2 upset daughters
did u try plugging them back in to the car ,maybe they heated up if so plug them in leave them for as long as when it happened and then try with a pliers for extra grip(twisting), a bad idea would be to splice the wires with the wall chargers by cutting of the ends and joining them that way but you would need to now what you are doing
Feb 25, 2009 | Nintendo DS Lite Console
My ds charger plug is bent
The only concern is if the connectors inside the charging station is corrupted. The bending is simply the outer metal connection, then bending it back wouldn't cause any damage. If the problem is further inside the station, it needs to be replaced. Nintendo can replace it for you for an acceptable price.
Jan 03, 2009 | Nintendo DS Console
Nintendo DS Lite power adaptor disconnection problem
There is a small latch on the connector that may be stuck. Try this. Turn the DS Lite upside down with the charger plug facing away from you. Press down the on the plug gently with your right thumb and with your left hand pull the connect away from the socket. FYI this should be a simple fit! Make sure the connector was not jammed in upside down to start with. It has a clear six sided shape to it!
Dec 23, 2008 | Nintendo DS Lite Console
Charger stuck in ds lite
Gently wiggle the charger from side to side, not too much incase you break the pins. it may be a little stiff to start with. Apply a fair amount of force and have lots of patience : )
Hope this helps,
-Deni-YO
May 16, 2008 | Nintendo DS Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
The adapter will not disengage from the console
you must forcefully remove the charger cable from the ds, try grasping the hard part of the charger cable where it inserts into the ds and have someone else hold the ds then pull. if it doesn't release still don't break the charger cable just send it off to nintendo and have them service it.
Dec 27, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
66 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
