Question about Video Game Consoles & Games
PS 2 : No Power
Hey thanks for that info....just want to verify that I have done some check right - if you have time-
Power supply all good, is it correct that I would have 5 volts at the switches and also at the connections in the disc tray????? Sorry am new to this tech biso!!!
  • LISC Jul 12, 2008
    Thankyou
  • LISC Jul 12, 2008
    Nah, haven't looked yet, am looking at PS for someone, they may want to spend a $100 and buy a new one!!!
  • 2,427 Answers
Yes that is correct
depending on the version
some use 12 and others 10
some use 5
But once you are getting power means the power supply is good
Only other cause for problem there is the board
Posted on Jul 12, 2008
  • Rishi Roshan Ali Jul 12, 2008
    hey any luck finding a board
    Yeah that is what i would have done
Samsung ps42q9 psu keeps tripping or doesn't even start up
EITHER 2 THINGS
1 ST. HAVE YOU INSTALL ANY THING NEW HARDWARE OR SOFTWARE, IF SO THAN IT IS HAVING A CONFLICT WITH POWER SUPPLY.
2ND IT MAYBE GETTING OLD AND WARNING OUT
3RD CHECK MAKE SURE NO DUST BUILT UP, BLOW IT OUT
TRY IT AGAIN
IF ALL FAILS BUY A NEW POWER SUPPLY DO NOT BUY THE CHEAP ON BUY A GOOD ONE LOOK AT WHAT YOU ARE GOING TO USE IT FOR.
IF YOU ARE USING FOR BUSINESS BUY GOOD ONE
IF YOU ONLINE SHOP FEW HOUR A DAY BUY CHEAP
IF YOU ARE A GAMER OR STREAM A LOT BUY THE BEST.
ALL POWER SUPPLIES ARE NOT THE SAME. AND DO SOME RESEARCH. HERE SOME HELP! LIST LIST WILL COVER EVERY THING YOU WILL EVERY NEED TO KNOW ABOUT POWER SUPPLIES. ITS 19 PAGES LONG & FILLED W/INFO
http://www.tomshardware.com/forum/292327-28-best-power-supply-brand
thank you rod
PS OTHER SITES
www.tweaktown.com
www.hwbot.org
www.thinkcomputer.org
www.motherboards.org
www.harewarecanucks.com
www.gamehacking.org
www.pc-techniker.org
www.customize.org
have fun
Mar 01, 2015 | Samsung Computers & Internet
Kenwood PS series DC power supply - maximum voltage issue
First thing to do is check the unit with an external meter to see if the internal ones are accurate.
Mar 17, 2017 | Kenwood Computers & Internet
Lacie ED mini v2 won't start up.
I had the same problem twice, but it was the power adapters each time that were causing the problem. It wasn't the unit itself. Lacie replaced the power adapters and it worked fine.
Nov 08, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I have customers overseas that have the EMACS HP2-6460P power supplies in their systems and they say that the systems do not shut down properly and they eventually unplug the power from the wall. What...
I would ask the customer a few questions:
1. Do you have the computer connected to a power adaptor or is it a voltage switching pc?
2. Has the pc always done this? If not, have you changed any power setting in the control panel? (Or have the checked the power setting.)
3. When was the last time the pc shut down properly? Maybe the pc is trying to install updates and need time to finish the install. (If when powering off the pc you see a shield over the power icon from the start menu, let the pc run its course and it should power on/off correctly.)
Good Luck
C2Solutions
Aug 13, 2009 | HP2-6460P EMACS PS/2 460W Power Supply...
Speakercraft infrared system with AT-1.0 Amplified Terminator, IRC-1.0 Receiver, PS-1.0 Power Supply and IRE-3.0 Emitters. Not functioning - no light on the Receiver and no lights from the emitters when...
From the power supply. You can meter a power supply with a multi meter. As for the terminator; they rarely go bad. Chances are good that you have a bad receiver.
Jun 28, 2009 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Starter issues
I would first verify battery power, Once you have proper power there, either via a good trickle charger or battery replacement, I would check the fuseable links mounted right at the "hot" side of the starter. Just follow the 4 gauge wire from the battery to the 15mm/13mm nut on the starter. Make sure you have power to both sides of the wire with a test light. THis is the only wire that supplies the power for the relay fuse box. So either your not making power, or the power isn't reaching this box. Let me know how you make out.
Jul 12, 2008 | 1996 Pontiac Sunfire
Pyramid 35 amp regulated power supply
Use specified power supply by the computer.
Feb 05, 2008 | Computers & Internet
Unit shut off after 15-20 minutes
The problem is IC 451, (Yamaha Part # XU814A00) (Number on part PQ05RD11 Made by Sharp). It's a + 5V 1A Voltage Regulator.
It's located at the bottom of the power supply board mounted to the front heat sink. It's a four legged TO220 Package outline. So don't try to slip a three legged 5 volt regulator in it's place. This can cause serious damage and headaches. Change this part and everything should be good.
Nov 15, 2007 | Yamaha RX-Z1 Receiver
Ps/2 keyboard port not working
Slim, Other than saying well it was a good couple years for the board lets just verify: Have you tried a different keyboard? Check device manager and see if you uninstall the keyboard and then reinstall it. Or have you recently installed any new devices that may have taken the resources away from the keyboard plug? If not get a usb keyboard and make sure you info is backed up...just in case. Good Luck, Tim
Feb 10, 2007 | MSI KM3M-V Motherboard
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
