Question about LG Kitchen Ranges
Replace stove top for LG Model- LRE30451SWST/ How! THANKS TIM
2 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
Posted on Jun 06, 2009
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
LG stove - glass cooktop broken - model LRE30451SW/SB/ST how do i remove and replace glass cooktop on LRE30451SW/SB/ST?
Open the oven door and you should see screws on the overhang where the door fits in,take those off and that should loosen the whole top of the stove,then you will see what to do next and what you have to remove to replace what you need,hope this helps some what.
Feb 19, 2014 | Kitchen Ranges
On stove bulbs what is the wattage I need to replace the two bulb's. Everytime I purchase bulbs they don't last long. LG microwave, model # lmvm2055st Thanks, Dave
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
Jan 03, 2011 | LG LMVM2055 Convection/Microwave Oven
LG dryer DLE 3733S control panel inop but light on in drum. 3 years old intermittent problem, is this electronics panel going bad? if so, do we replace PCB Main or PCB Assembly? Thanks!
Check the power to the display panel after you have it removed. If there is no power check the lines to the control, If the power is present with no action on the panel then you will have to replace the board. It may be as simple as cleaning the board off, since it has been a intermittent problem in the past. hopes this helps Tim
Nov 25, 2010 | LG DLE3733 Electric Dryer
The electrical buttons from the left stop working, so i can,t use my left side of tge stove
You may have a model which is covered by a LG service bulletin, concerning the oven vent. Contact an authorized LG service provider with your complete model and serial number to have them check. (If you have one, the fix is to replace the oven vent tube with one of a slightly different design, and to replace the key panel. This condition often causes discororation on the left side of the backsplash also)
Jun 16, 2010 | LG LRE30755ST Kitchen Range
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
Lg flat surface stove burner
Replace your infinite switch for this (your lf burner switch). Call a parts supplier with your model number, try and get an exact switch, not a generic switch. Do not replace the switch without unpluggin your range first. Good Luck, Appliance Specialists
Jan 28, 2010 | Kitchen Ranges
Bulb for lmvm2055st lg microwave
Can't help with part number as it's not an Australian Model, but refer to http://us.lgservice.com/index_b2c.jsp to help you find a service location!
Jan 12, 2009 | LG LMVM2055 Convection/Microwave Oven
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Kitchen Ranges Logo
548 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
