Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Warped picture Toshiba 65HDX82
After changing the whole convergent board..the picture is the same..warped in from all sides of the screen
  • Toshiba Master
  • 3,459 Answers
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Mar 25, 2010
The tv vision is red, green, yellow, orange, very very blurry, and it is not possible to watch the television. How could I fix it?
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2011 | Akai PT5492S 54" Rear Projection...
Toshiba 65hdx82 convergence issues
check fuse resistors near STK, and broken PCB around digital convergence board (board in a metal box verticaly mount beside STK.
Apr 23, 2010 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65hdx82 has a squiggly distorted side to side picture from all inputs. It gets slightly better after it is warmed up but still very bad. When you go into a menu screen that seems to be OK.
Ur convergence is the problem.U know how to solders?Tries websites.Tv repair World.com,Tvrepairkits.com for convergence kit,replaced what in the kit.
Dec 15, 2009 | Toshiba 65HDX82 65" Rear Projection...
RCA D61W20 Projection Television with ITC222 chassis Here is the whole thing , took this machine apart last night the mirror is in good shape cleaned the lenses, picture is much brighter now! However still...
unfotunatly the itc222 has no convergence ics it uses a series of trsansiitors. the fact that u have some areas of the screen clear may mean you need a technician to do a service alignment. when you go into setup does the convergence crosshairs move up and down and side to side on both the blue and red? if they do their may not be a problem with the power board. ONe more thing if you replace this board you will still need a technician to do a service alighnment
Jun 16, 2009 | RCA Televison & Video
Toshiba 65hdx82 convergence problem, pincushion
Your TV most likely a failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 19, 2009 | Toshiba 50H82 50" Rear Projection...
Distorted Picture
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
65 Toshiba picture sides are bowing in.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 21, 2008 | Toshiba 65HDX82 65" Rear Projection...
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
