Fixing a ballast
  • Where can we purchase a " Ballast"??? What does a ballast look like, the Tv was manufactured in 2004:
    Model #44pl9522/17: Phillips Liquid Crystal TV
No our problem was not fixed.
Posted on Jul 14, 2008
How do i install a new ballast for projection lamp ballast in mitsubishi model wd 52327
Not sure if this is your TV for it don't specify a model of TV, only stating a V41 Ballast
https://docs.sony.com/release/KP53S75.PDF
This video specifies nothing but goes more in depth w/audio
https://www.youtube.com/watch?v=5frOnh58Z6M
TV's shown are different but the ballast part is the same (location and cables).
Dec 11, 2014 | Mitsubishi Televison & Video
I was told I need a new lamp ballast assembly. I was also told by someone to order 6913V00002C Ballast (EUC 100 P/11) but when I opened my TV and took out the "bad" ballast, its is a EUC 100 C/00. Anybody...
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Oct 22, 2013 | LG RU-60SZ30 60" Rear Projection...
How do I replace a lamp ballast in my Samsung model # HLS5086WX/XAA?
The ballast should come out fairly easy---at the end of the 2 red wires where it connects to the lamp should be a single screw and the lamp has to be already removed---with the screw at the wire end removed the socket lifts up and to one side and the actual ballast is secured with no more than 4 screws and has only one or two small plugs to remove
You might also check You Tube to see if they have video instructions there for your model.
Mar 20, 2012 | Samsung Televison & Video
I have a toshiba 46hm94p dlp tv. i need to replace the ballast. i pulled the tv apart and got the part number off the ballast, it is RPB-4434ZA . when i look that up by the part number it says its the...
yes they both the same part number one is board number and other is manufacturer number, board number is what it is and manufacture number is if its in other tvs.
Jul 15, 2017 | Toshiba TheaterWide 46HM94 46" Rear...
Samsung 60 inch tv keeps turning off and on
Well we need to have in mind how old is your lamp,if you have a generic lamp it could last you from 3500 to 4500 hrs and if you have a Phillips that could give you 6000 to 8000 hrs and a weak lamp could cause for the tv to be turning on and off,if you just purchase a new lamp and just starting to get this problem it could be that you ballast is to weak to power your knew lamp,BALLASt= small circuit board that regulates the correct amount of current to the lamp,
You can get some help troubleshooting @ discount merchant.com or at fixyourdlp.com?click=52978
best of luck and please keep us posted
Dec 09, 2009 | Samsung Televison & Video
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
2004 Samsung DLP HLN-507W1X:Flashing lights
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
Sep 21, 2009 | Samsung Televison & Video
Ballast replacement
Your set uses the Phillips UPH100W 1.3 100http://servicemanuals.vstore.ca/ 1amp bulb part number 6912V00006A which uses Ballast EUC 6913V0002A and the actual ballast isMB03CA part number 6871VSMB13F I would contact LG and give them these numbers. Is your ballast bad or is the BallastEUC bad? Let me know if I can help you further.
May 12, 2008 | LG RU-60SZ30 60" Rear Projection...
My TV screen is blank for my 62" Toshiba
I just replaced the ballast in my 52HM84, working fine now. My 2 cents:
Remove the lamp. Remove the lower back panel (13 screws), remove the housing behind the lamp door (2 screws).
I only slid the light engine out a few inches, enough though that I had to remove the plastic panel oriented horizontally between the projector lens and the backside of the tv.
You dont need to remove the screws that hold the lamp plug.
The ballast board is held down by 4 plastic retaining clips, push each gently to release the board from the aluminum housing. You do not need to unscrew the aluminum housing from the light engine tray. ( Be patient, read on )
Disconnect the 2 cables attached to the ballast board.
I know you are thinking, how do I remove the ballast board with the lamp plug where it is.
Orient the lamp plug on your new ballast to match the old and use a piece of tape to mark the top wire of the 2 lamp plug wires. Not sure that it matters, but why take the chance.
On you new ballast, find the tiny hole above each larger conductor hole, poke a paperclip in the small hole to release the wire. I've done it with a paperclip, you may try to use a pin or needle. Repeat on the old plug.
Your ballast is free at last.
Put the new ballast in place over the 4 plastic guide pins (part of the plastic retainer), the board should click into place.
Attach the cables to the board.
Insert the lamp wires into the back of the lamp plug, you did mark the top one right?
I won't bore you with the rest, because you've already been there.
The biggest mistake I made was allowing the housing that has the door interlock switch to fall off the table. Of course, this pulled the plug off the circuit board and it's not the light engine board either. Didn't know it had detached until I powered up and got the LED's blinking indicating the door was not properly secured. So I had some extra stupid work to re-attach it.
But I have LIGHT.
Nov 17, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
