Power surge on usb port
I have an acer travelmate 290 series notebook, i got a message power surge on usb port while i was using my web cam and now all usb ports dont work, including the laptop speakers....help me fix this please
  • Anonymous Jan 01, 2009
    my laptop is giving the same power surge usb power message
  • Anonymous Mar 15, 2009
    my eee pc laptop speakers dont work
    Genius:
  • 1,019 Answers
unless your a very competant motherboard components repairer.
this is beyond repair. i,d suggest taking it to a repair centre, where they will replace the motherboard. and unfortunately a large invoice to go with it. probably more cost effective to look at a replacement laptop.
Mike @ Compurepair.
Posted on Jul 31, 2008
Ports on acer travelmate 4200 not working?
sounds like you may have driver for usb ports missing. check in device manager and see. if so simply reinstall drivers
Aug 12, 2012 | Acer TravelMate 4200 Series Laptop Charger...
What is a drawbacks of disabling usb power manager i have acer travelmate 290 laptop, and wen ever i use high speed Internet modem it some times shows the message "the usb port has exceeded its ports...
Personally, I would favour the use of a High Speed Powered Hub. It will ensure no damage to the USB Port due to overloads.
Less than a tenner on Ebay is a good price for piece of mind.
Apr 17, 2011 | Acer Computers & Internet
The USB Ports on my ACER TravelMate 2350 Series Laptop, I have deleted the USB Port files from Device Manager and the machine reinstalled them when I re-started but it didn't change anything. I downloaded...
I'm guessing your USB ports don't work or does it always ask you to install them. If you have your Windows XP license key at hand, please try downloading and installing the following...
Acer TravelMate 2350 XP Chipset Driver
Reboot. It might ask you to do a reactivation, or not.
Please recheck if your USB ports still work. If not, restart your machine, hit F8 continously until you get many options - choose the option "Safe mode" and press Enter. Check if it picks up USB in this Safe mode.
What you can also try, is that you have 3 different USB 2.0 ports on your machine. Try each one separately and see if one of them works. I would also recommend to see if the USB device you are trying to use is actually functional.
May 19, 2010 | Acer TravelMate 2300 Notebook
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
Can't make webcam work on Acer Travelmate 4500
This sounds like a USB issue. Not all USB ports on laptops are created equal (they should be but they are not) some usb ports supply enough voltage and current to run usb items properly and some dont. It is always better to run direct from the computer / laptops ports .
If you cant do this then use a HUB but make sure the HUB HAS IT"S OWN POWER SUPPLY !
Also make sure you always use the same port and swapping them around does not always work for all hardware.
Aug 09, 2009 | Microsoft LifeCam NX-3000 Personal Web...
Hi i have an acer laptop 5000 series the usb ports will not work saying power surge overloaded,would buying a usb card solve the problem.Any help would be much appreciated.
are you using windows xp sp2, this issue normally occurs with it
a fast fix is:
go to start menu> run > type in devmgmt.msc > ok
1) Device Manager will open
2) Locate "Universal Serial Bus controllers" in the list and expand
3) Select the first USB Universal Host Controller.
4) Right click and select "Properties"
5) Go to the "Advanced" tab
6) Check "Don't tell me about USB errors"
7) Click "OK"
Note. If you have multiple host controllers then they should all be affected by the above action.
8) Close Device Manager
further Queries are welcome
Feb 18, 2009 | Acer TravelMate 4100 Notebook
How to use my usb port for booting my acer tm290 series?
First off your BIOS must have a "Boot to USB Hard Drive" option available. Then you need to configure the drive boot order; USB-HD -> CD -> IDE -> SCSI. Then the micro-drive must be formated with the "Boot" or "Active" partition flag enabled. If you are trying to boot Ubuntu there are several tools you can download that format the USB drive and set the boot flag for you.
Nov 28, 2008 | Acer TravelMate 290 Notebook
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
Web cam problem
1 - check for the webcam driver...sometime uninstalling and reinstalling the webcam driver gives a result in such situation.
2- check the integrity of your webcam connection via usb ports ; check usb ports too ; try other usb ports if possible.
May 27, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
936 people viewed this question
David Payne
David Payne
