Question about Dishwashers
The dishes no longer get clean even though the water is getting through....are there filters I need to clean or could the soap dispenser be a problem....please help
    President:
  • 1,462 Answers
There are filers in the inside bottom of the machinbe which should be taken out and cleaned regularly.
problem may be that the spray arms are not rotating. open the door when in cycle and check each arm rotates(you will get a bit of water out)
if they are not, the problem is probably debris in the arm so take them out and clean (this is quite tiresome to do and the usual culprits are rice and sweetcorn)
the arms only rotate by water sqirting out of angled jets at the end of the arm and if these are blocked then arm doesn't turn
Posted on Jul 12, 2008
Top rack not washing. All soap not cleaned out of dispenser
This may sound ridiculous, and I'm no "expert", but are you starting out with really hot water (i.e. running the faucet at the kitchen sink until hot water comes out)? My wife refuses to do this and she encounters the same problems: dirty dishes and leftover soap. *I* make sure that hot water is readily available to the dishwasher (even though it's *supposed* to heat it for you) and never have either issue.
Feb 07, 2012 | Dishwashers
Kitchenaid KUDP01 not cleaning dishes
Remove the accumulator assembly and check the chopper to see whether it's clogged or damaged.
Jul 02, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Mar 29, 2009 | Dishwashers
    The water will not drain from dishwasher. What should I do?
    Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
    However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
    Mar 18, 2009 | Asko D1716 Built-in Dishwasher
    ASKO MODEL 1996 WILL NOT WASH DISHES
    Mar 14, 2009 | Asko 1996FI Dishwasher
    Soap hardens in the dispenser and dishes don't come clean
    Either your dishwasher is not getting the water hot enough to dissolve the powder, or you need to switch brands. Try a liquid/gel type of dishwasher detergent.
    Try stopping the washer a few minutes after you start a wash cycle. Open the door -- if there is a lot of steam coming out at you, it's not the water temperature. If there is no steam, your dishwasher is not getting hot water and/or the heating coil is not working.
    Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
    OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
    I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
    Dec 04, 2008 | KitchenAid Dishwashers
    I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
    The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
    Jun 29, 2008 | Dishwashers
    Dishwashers Logo
    159 people viewed this question
    Top Dishwashers Experts
    Mike Cairns
    Mike Cairns
